Old 04-02-2002, 05:03 PM
Question Look at all of the hoses
I just started to mount my external transmission filter, and look at all of those hoses! I have an external cooler now, but want to add the filter to the system which also has a sending unit for my digital temp gauge.
The QUESTION --- which is the in and which is the out port on the radiator cooler? I want to add the filter before it goes into either cooler, and I can't figure out if it goes through the radiator cooler first, or through the external cooler first. The cooler is in a very cramped area, and I can't see the order of things. It was done before I got the car. If someone could check to see which port is in and which is out, it would be a big help. Please use drivers side or pass side for a reference. Thanks
Old 04-02-2002, 05:26 PM
dart
Re: Look at all of the hoses
The passenger side port on the radiator is the inlet. I 'd like to try one of those filter/temp sending units on mine. Where can they be had?
Old 04-02-2002, 06:31 PM
I have a Perma-cool filter, which has the hole for a sensor, and if you don't use a sending unit, they supply a plug for it. You can install the sensor at a later time. The filter was around $38.00. The number is #10678 which doesn't come with a sensor or temp gauge. The #10677 comes with the sensor and temp gauge, but I don't know how much that one is. I got a different gauge and sensor. It is a Dakota Digital and you can go to the link and see what it looks like. It is around $ 100.00 for gauge and sensor. Thanks for the information on the ports.
http://www.dakotadigital.com/Detail....umber=ODY-08-3
Old 04-02-2002, 07:54 PM
dart
And thank you for your info
