WAY off topic
I know there are some cyclists/mountain bikers here - any clue what's going on when you start to hear a click or knock from the area of the bottom bracket? Has to be that because it matches each pedal stroke.
Bad bearings? It has a little over 2000 miles on it.
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
I haven't ridden my bike in a long time, but I have had this problem before. I actually cracked the bottom bracket and it was clicking every time I cranked. I would venture a guess that you need a new bottom bracket.
How do your cranks look? Are they tight? I once stripped the bolt out of the crank. It made a similar sound as the bottom bracket. Wow, I sure have broken my bike a lot....
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
It's funny that you should post this - I literally just finished tuning up a friend's StumpJumper. Learning that I can still tune a bike to ride like that put a smile on my face.
Sounds like a bad bottom bracket to me. What kind of bike is this? Bottom brackets rarely match the level of components you see on the rest of the bike. If you ride a lot, I'd recommend investing in a really nice replacement. High-end Shimano, like LX or XT. Of course these days the bottom bracket spindles are splined. If you bike is older with the squared spindles, you might have a little difficulty finding the right bottom bracket - especially in the right length. I know the bike only has 2,000 miles on it, but all it takes is one good submersion to compromise the seals or lots of dust to grind them away.
You SVX people are so fussy about weird noises. Leaky exhaust, whining differentials, grinding transfer clutches, ticking lifters, clunking windows, and now you're bringing bicycles into it. The only noise my SVX makes that drives me nuts is the silly door chime. *Sigh* It's time for official SVX ear plugs.
Okay, okay. Umm, sometimes my derailer gets bent and bumps the crank. |
Bad bearings is correct I had a Royce Union bike that did that the first summer I had it. Lucky for me it was under warranty, and they gave me a new bike.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I will second (or third) the bad bottom bracket bearing diagnosis. I got about 4500 miles out of an XT bottom bracket on my touring bike before it started clicking, so 2000 on a hard-ridden mountain bike may not be unusual.
Pop the cranks off and spin the spindles with your fingers; if you feel any uneven resistance it is almost certainly bad bearings. Spinning the cranks with the chain off may work too, but it will be more obvious with them off. It is really fun to say "pop the cranks off and spin the spindles".
First the smiles, then the lies. Last comes gunfire. |
Right you are. I constantly obsess with any noise that seems out of place in the car or bike, actively seeking it out each time I drive/ride. Fitting that my favorite car turns out to be an SVX.... I took my bike (Trek 7000, vintage 1998) to the bike shop, expressed my concerns about the possibility of bearing troubles. They ended up tightening the crank and pedals. I took it for a short ride, applying what should have been more than enough load to duplicate the noise and it was nice and quiet. So...not really sure yet til I get it back out on the trails.
