Old 09-10-2003, 05:36 AM
svx_commuter's Avatar
My shaft has stiff joints.
The propeller shaft, drive shaft, has stiff U-joints, that is.
Any idea how long they will last?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 09-10-2003, 06:38 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Re: My shaft has stiff joints.
Not long. The faster you drive, the faster they will freeze up.
I have a propeller shaft with good u joints, but a torn center CV boot. Wanna trade?
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 09-10-2003, 08:23 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
>>QUICKLY GRABBING DUCT TAPE. TAPING HANDS TO CHAIR ARMS TO AVOID TYPING <<
Randy Johnson
Mike Davis -- at Reading VI
Old 09-10-2003, 10:58 AM
Okay Doug not long. The shaft is still free to move in and out. It's just that when I hold in the hand and and try some gyrations that it feels notchey at the joints. So you think the lubricant is all dried up inside? I guess after all that action in the past 180k miles it's pretty hard, the grease that is.
So. Ah. Yes. I would like to trade. Please send me your drive shaft and I'll use it for the next 10 years and then I'll send it back to you with mine.
So how much for a new drive shaft assembly? I may be looking at new front exhaust pipes and what the heck since the rack is original I might as well do that while I got everything apart and up on JACK STANDS.
Old 09-10-2003, 11:30 AM
Aredubjay's Avatar
MUST NOT BREAK DUCT TAPE, MUST NOT BREAK DUCT TAPE, MUST NOT BREAK DUCT TAPE . . . . .
Randy Johnson
Old 09-10-2003, 11:38 AM
RSVX RSVX is offline
Network Design Administrator
Im right there with you Randy... LOL
Doesnt this belong in the "Not Exactly SVX" Forums? And thats awful personal stuff to talk about on this forum...
Life is a game. Play to win.
Old 09-10-2003, 12:02 PM
mohrds's Avatar
The Driveshaft is not serviceable (according to Subaru). I've had the ends cut off and serviceable yokes and U joints welded on for under $200.00 Unfortunately, they cannot find a source for either the center CV joint boot or replacement center CV joint that will fit inside our driveshaft tunnel
The replacement driveshaft from Subaru is about $450
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 09-10-2003, 12:14 PM
srmifer
one word
WOW
Old 09-10-2003, 01:00 PM
wawazat??'s Avatar
Yeah, I'm still around
So men the message here is this
don't get old. Your shaft and joints get stiff and are expensive to replace, welding only cures part of the problem and it requires the ends to be cut off
Todd
Down to none
Old 09-10-2003, 01:03 PM
Aredubjay's Avatar
>>BLOOD RUNNING DOWN CHAIR ARMS FROM CUTS CAUSED BY STRUGGLING AGAINST DAUNTLESS DUCT TAPE<<
Randy Johnson
Old 09-10-2003, 01:14 PM
Doug, I am thinking about injecting some grease or oil or something into the rubber seal on the u-joints with a needle. That's a lot of money for the drive shaft. But then again it last a long time ~ 10 years 200k miles. The exhaust has also lasted a long time. Maybe the replacement exhaust is worth the money too. How about the rear diff? Most likely needs a rebuild to reduce backlash. I changed the fluid in mine recently. It was changed about 100k ago and I was surprised that it was sort of gray looking. I'll have to change it more often.
So at about 200k replace the exhaust, propeller shaft, rack and and and and what else?
Old 09-10-2003, 02:56 PM
mbtoloczko's Avatar
sans SVX
I've had the opportunity to examine one early model driveshaft (center CV joint) and 3 late model driveshafts (center u-joint). All had 100K miles or less, and one of the late model driveshafts had only 36K miles on it. All had at least one stiff and/or notchy u-joint, and all except one (mine) were purported to work fine. So, my feeling is that your driveshaft with stiff and/or notchy u-joints has probably been like that for at least 100K miles if not 150K miles.
Mychailo
Visit my locker
Old 09-10-2003, 03:46 PM
Trevor's Avatar
Trevor Trevor is offline
Re the suggestion of injecting grease/oil.
I have had good results and saved money and effort through greasing CV joinjts said to be US. Can you get grease in under the edge off the boot, after removing any attaching clip, using a gun or syringe ? Well worth a try.
Randy,
I trust you have a tool in hand to remove your restraints. Meantime enjoy !
Trevor, New Zealand.
Old 09-10-2003, 07:20 PM
Subafreak's Avatar
Superbeast
Ya what he said. The joints are ussually stiff if you try to move them around alot, but if you think about it our shafts don't move around alot like in a strait axle car. The joints should work fine for a long time still, they don't really have to move that much anyway.
Old 09-10-2003, 08:45 PM
Invisible avatar
Talking
The joints should work fine for a long time still, they don't really have to move that much anyway. [/B][/QUOTE]
Yup...marriage'll do that to 'ya.
Ron (Duct tape be damned)!
'96 Grand Caravan - 240K
'01 Miata SE - 79K
