Old 06-27-2003, 11:32 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Did you...
bleed the brakes after you installed the new rotors and pads? You have to start at the ABS box in the engine compartment.
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-27-2003, 11:40 AM
tuzem
Why bother designing all this? Seems too complicated to me ) Anyway.... I've decided to order the guide pins for my front calipers and see what happens..... Do you guys know if subaruparts.com has a location. I see they are in Washington, but if they are close by I might as well go and pickup my stuff instead of waiting for shipping.
So, what's the best way to see if my rear rotors are warped then?
Thanks all for the input!
NIck
Old 06-27-2003, 11:43 AM
tuzem
SVXRide,
I didn't bleed the system. Was I supposed to?
Old 06-27-2003, 05:49 PM
Subafreak's Avatar
Subafreak Subafreak is offline
Superbeast
You shouldn't have to bleed them if you didn't open any bleeders while doing the brakes, unless it's really dirty then you should flush the whole system.
You should be able to feel if the rear disks are warped as opposed to the front. The front you can feel through the steering wheel, the rears you can feel through your but.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs.
91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch.
78 BRAT (New toy) (Soon to be EJ22T powered)
90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car)
To many cars to spend time on teh web!
Old 06-27-2003, 09:00 PM
SVXRide's Avatar
I'm guessing his brake system has never been flushed and is full of air/water/assorted crap. I know the fluid in my '92 looked like mud when I bled it after I put on new front rotors and pads.
