Old 06-23-2003, 09:27 AM
matt matt is offline
Send a message via ICQ to matt Send a message via AIM to matt
Ball joint to control arm bolts...
http://www.subaruparts.com/subaru.diag/2A/i200-1.gif
20258A bolt
023512006 nut
Where can I get the nut? No luck from Subaru or local places.
86GN
95SVX
81RX7/302
Old 06-23-2003, 09:52 AM
Mr. Pockets's Avatar
Moderator
I imagine it's a standard nut you can get at an auto parts store. I don't remember anything special about it.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-23-2003, 10:00 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
023510006 Nut Self Lock $2.74
20201PA020 Bolt $2.26
They are the same self locking (mutilated threads) as the front sway bar linkages use.
http://www.subaruparts.com/diag/?mod...category=200-A
What do you mean no luck at Subaru? Are you looking for something that's in stock? Then you are probably out of luck.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 06-23-2003, 10:13 AM
Moderator
Doug
Were these nuts and bolts I wasn't supposed to reuse, Doug? I had to pull my ball joints off the control arms to get the front axles out of the front diff.
2005 Outback
END OF LINE
Old 06-23-2003, 10:21 AM
Doug
No luck as in they had no listing for it. Who stops when they don't have it in stock??
Are you positive they're the same?
Old 06-23-2003, 10:46 AM
mohrds's Avatar
They are the same according to the parts diagrams. They have the same part number.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 06-23-2003, 10:49 AM
mohrds's Avatar
I dunno. I don't have the manual handy. Generally I have seen the FSM warn you not to reuse self locking nuts in the rear suspension. I have reused them with over 100,000 miles and no failures........yet
They will be replaced when I rebuild my suspension soon.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 06-23-2003, 12:03 PM
Moderator
Doug
I just didn't know they were 'self-locking' at all. The looked normal to me...
2005 Outback
END OF LINE
Old 06-23-2003, 12:13 PM
mohrds's Avatar
I think that "Self Locking" means that they came from the factory seconds box and the threads aren't cut perfectly clean and aligned. That way they bind when you install them and wont wobble loose
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 06-24-2003, 10:46 AM
svx_commuter's Avatar
Nuts have a coating to prevent rust.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
