Old 04-14-2003, 06:07 AM
tag007
Anyone changed out a SVX windshield?
Had this over in the Tech QA, thought I would drop it here too.
I am needing to change out a windshield. I have picked up a salvaged one recently, and was wondering if anyone has any experience with this?
The windshield is currently rather fixed to the rubber gasket, and it seems that this is completely in tack. I have also noticed plastic fasteners attached to it and a thin bead of the original adhesive.
It seems that the adhesive is the only thing that secures the windshield...If anyone knows if I will need a new gasket, and if so, how to remove the old one, , or what exactly I might need to do.
Thanks.
-Trent
Old 04-14-2003, 07:30 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
push out from the inside
i'll pop right out
all cars are required to have a quick removal windshield, for safety purposes as a method of escape fromt he car
putting the new one in, and sealing it properly is a different story
SV What?
Old 04-14-2003, 08:11 AM
iyamwutiam
wINDSHIELd
pLEASE TELL ME THE STORY OF PUTTING IT IN - AS i HAVE LOCATED MY WINDSHIELD. aND THE PLACE WILL NOT DO THIS FOR ME.
Old 04-14-2003, 10:15 AM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Originally posted by NomadTW
push out from the inside it'll pop right out
Where did you get this info from?
Most windshields these days are installed using urethane caulk.The only way to remove them without destroying them is to cut them out and sometimes they break in the process.
That stuff is so strong the the windshield becomes an integral part of the body.
The rubber around the outside is probably just a trim piece and is usually replaced when the winshield is replaced.
Old 04-14-2003, 12:37 PM
NomadTW's Avatar
iduno where i got it, it was told to me by someone.
made sense and they're usually right abotu this type of thing... so i had no reason to doubt
SV What?
Old 04-15-2003, 07:45 AM
JeffN JeffN is offline
Sube did ours when new as it wobbles and creaked in it's frame. No probs since itwas done. Actually they just resealed the orig glass-no new glass.
Old 04-15-2003, 09:13 AM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
This is why you should have the windshield installed by a professional glass installer. The glass becomes a structural member of the vehicle. The adhesives used are very strong and usually have a specific pre-cleaning, prep, and application method to ensure a proper bond. I wouldn't try this one at home.
Down to none
Old 04-15-2003, 09:31 AM
tag007
I had no intention of doing this myself. The problem is, the auto glass installer where I live, has never done one either, I just want to make sure I have as much info, and any related parts, I need in order to get this done correctly. So again. If there is anyone of here that has first hand experience with this, and do i need to change out the rubber dam even though it seems perfectly intact, let me know...
Display Modes
