Old 10-30-2005, 03:07 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
She's a smoker
My SVX just started to develop a smoking problem. Oil coming from the valve covers is the culprit. Anyone have a clue as to how much the gaskets are for the valve covers?
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 10-30-2005, 03:43 PM
Manarius's Avatar
Manarius Manarius is offline
Gaskets are cheap. However, doing them is a pain. In my car, it's relatively easy with a lot of open space in the engine bay..SVX..not so much engine room.
-Jason
-Obi Wan Kenobi
Old 10-30-2005, 03:49 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
You'll need the gaskets (like 3 of them and will want to replace the grommets). Figure about $60 per side from www.libertysubaru.com It'll probably take ya about 3 hours or so per side unless you've had some experience. Definately easier if you remove the battery, airbox, coolant tank and water washer tank from the get go but still a pain. Not something I'd recommend for a novice around the engine as chances are you'll overtighten something and it'll still leak.
Old 10-31-2005, 12:58 PM
The gaskets are cheap...once you add up all the grommets it gets a little expensive. I've currently got on order enough to change 2 engines.
Old 10-31-2005, 03:06 PM
Like 8 months ago, i removed the whole engine jsut to change those gaskets and convert the plastic thing in between the engine and tranny into an Aluminum piece with its sealings... sometimes i hate boxer engines
Old 10-31-2005, 09:09 PM
MNYPNNY's Avatar
MNYPNNY MNYPNNY is offline
FKA....thndrmtn92svx
Alcyone Silver Contributor
Send a message via AIM to MNYPNNY Send a message via Yahoo to MNYPNNY
Parts are pretty cheap.... my mechanic charged 2.2 hrs labor.....
~~Michelle
'92 LS-L - copper - 190K miles
'94 LS-L - pearlie - 92K miles
*still have '92 parts*
Old 10-31-2005, 09:15 PM
THAWA
What plastic thing between the engine and tranny?
Old 10-31-2005, 10:11 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
i believe its the rear main seal. mine is cracked too and so is svxfiles'.
Old 10-31-2005, 10:16 PM
THAWA
Ooooohhhhh, that plastic thing. Yeah, that's not the rear main seal. That's the oil/water separator plate. Definately replace that. The plastic ones are bad and like you said, tend to crack.
Old 10-31-2005, 10:27 PM
What the heck is a grommet?
Old 10-31-2005, 10:47 PM
THAWA
In the context it's the little metal/rubber seal that seals the valve cover bolts.
Old 10-31-2005, 10:54 PM
Oh yeah mine are nasty.
How do you get them?
Old 11-01-2005, 05:40 AM
benebob's Avatar
An auto parts store or the dealer.
Old 11-01-2005, 12:24 PM
Sounds shady.
Old 11-02-2005, 03:24 PM
Shady...
Five bucks for a friggin grommet?
I can't believe I just spent over $80 for 16 of them.
