Old 03-21-2008, 08:54 AM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
nobody's know that ? nor my book ?
Hi , do you know where the DRL ( day runing light ) module is located in a Canadian SVX 1993 ?? thanx
Nightmare is the name of the car...
Old 03-21-2008, 10:20 AM
Cynic's Avatar
Cynic Cynic is offline
I believe they are the "fog lights" on US cars. They were wired to be daytime running lights for Canada. When you switch on your lights at night, they go out, but you can use the dashboard button (next to the cruise control, left side of steering wheel), to turn them on at night (you'd have four lights).
Just my ideas, this is what I figured out from reading a lot of posts. So the module would be the same as the fog lights in the parts diagrams??
Cyn
Cyn
92 Ebony Pearl LS-L 199,000K New Tranny (my DD)
89 Chevy Sprint (for when my baby's in the shop)
05 Mazda 3 (Hubby's DD)
"You win some, you lose some, you wreak some." Dale Earnhardt
Old 03-21-2008, 10:23 AM
I want to take that out , thats why ...
Old 03-21-2008, 01:32 PM
Are you sure it is a 93? If so, what color and when is the manufacture date? Thanks.
Old 03-22-2008, 09:28 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
What does this module do? Are you sure the lights aren't just wired through a relay to ignition live? I'll see if I can find anything on the wiring diagrams.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-24-2008, 07:48 AM
I don't know anything about that ! Ain't there a fuse for the fog lights that would cut the power to that relay ?
Old 03-25-2008, 11:19 AM
b3lha's Avatar
Phil & Belha
I found it in the USDM factory service manual under "Canada Model".
The DRL module is above the glove box near to the cruise control unit. It has a white rectangular 2by5-pin connector. The wires are Red-White, Brown, unknown, Black-White, Green-Yellow, Red-Green, unknown, Light Green, unknown, Black.
There are two relays DRL#1 and DRL#2 under the dash on the driver's side near the ECU.
DRL#1 has a black connector with five wires, Red-White, Yellow-Black, Blue-Yellow, Blue-Black and Green-Yellow.
DRL#2 has a brown connector with six wires, Red-White, Yellow-Black, Red-White, Blue-Red, Red-Yellow and Black.
There is also a diode with Violet and Yellow-Black wires.
If you remove these parts then your lights may not work at all, day or night. What effect are you trying to acheive?
Phil.
Old 03-25-2008, 11:22 AM
thank you !!
thanx a lot ! that is a great answer !!! I'll pay you a beer sometime when i'll get by ... witch may be a couple of years but ...
Old 03-25-2008, 12:16 PM
b3lha's Avatar
Phil & Belha
Don't expect it to be an easy job. The engine comes out easier than the glovebox.
Old 03-25-2008, 12:17 PM
I'll manage something ....
Old 04-24-2008, 08:18 AM
Do you have the voltage that the DRL uses ? I want to buy from Tom some HID's and need them to run on 8 volts i think ...
Old 04-24-2008, 11:41 AM
kwren's Avatar
kwren kwren is offline
There is a fog lite fuse
Just remove the fuse
Old 04-24-2008, 11:45 AM
What fuse ? where ?? witch one !!!?
Old 04-25-2008, 02:31 AM
b3lha's Avatar
Phil & Belha
In my experience, removing fuses drops the voltage to zero rather than 8.
The DRL will be 12v. Are you sure that the HIDs aren't 12v also? 12v is the standard for car electrics (except for the digital electronic bits like the ECU), so it would be unusual that lights designed for car use would be anything else.
Old 04-25-2008, 06:25 AM
thats what Tom said :
Re: Fwd: HID 6000K ( white ? )‏
De : Tom Krynock (tom@svxfiles.com)
Envoyé : 24 avril 2008 02:36:47
Répondre à : tom@svxfiles.com
À : beaudrynormand@hotmail.com
As of this minute I can not say for sure if DRL would be a problem..
BUT, If your DRL run on over 8volts then the HIDs should work fine all of the time.
But I don<t know the voltage !!!
