Old 02-29-2008, 11:40 AM
Naim's Avatar
Naim Naim is offline
Send a message via Yahoo to Naim
I need to know if the A/C condenser coils are interchangeable between a 92 and 95 SVX
I have a 95 SVX with a bad A/C condenser, I found someone selling a A/C condenser out of a 92 (which used R-12).
I need to know if the A/C condenser coil is interchangeable. Meaning will it bolt up to the A/C lines in my car.
Thanks.
I bought the car for my wife, but it's my new toy :-)
Old 02-29-2008, 11:51 AM
JaySVX's Avatar
JaySVX JaySVX is offline
No they are not. R-12 molecules are larger than 134-A, and require different systems. That's why putting 134-A in an R-12 system will distroy it.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 02-29-2008, 12:08 PM
Naim's Avatar
I think my question was mis-understood...
I am not going change from R-134a to R-12 or vis-versa...
I need to know if a condenser coil from a 92 will work as a replacement in my 95 SVX...
Old 02-29-2008, 12:20 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
dont know about the 95, but I had a cracked ac condenser on my 94. I was able to swap it out with my 92 parts car. I did have to flush the 92 condenser with brake cleaner before bolt on my 94.
Good luck
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 02-29-2008, 07:20 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Then why can I buy a R-134A retrofit at wal-mart for a R-12 system?!
-Nate
'92 LS-L Pearlie
Old 03-01-2008, 06:59 AM
I've got a 95 Condinsor on my 92, so yes they will fit....
some of the lines are different, but the condinsor is the same.
Old 03-01-2008, 09:00 PM
Naim's Avatar
huck369, are you talking the A/C condenser or condenser coil (the cooling coil) that sits infront of the radiator?
What I need is the condenser coil..
It appears that pearlm30 swapped his condenser coil.
Thanks
Naim
Old 03-02-2008, 07:00 AM
Thanks
Naim
The one in front of the radiator is the same on all years...the one in the dash IS different where the li9nes attach to it...
