Old 12-20-2004, 01:55 PM
Unhappy Speedometer quit
While testing cruise control functionality in my SVX my speedo decided to quit. My first instinct was to check the speed sensor. It's securely plugged in. I do not get a check engine light.
Anyone have any ideas as to what order I should be checking for problems? I'm going on a long trip in 2 days so this is very important.
BTW, this is with the 5MT from a 2002 WRX.
(should I be pulling out my dash?)
Old 12-20-2004, 03:32 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
sounds like vss1 to me. Did it work after the 5 speed swap? I dont know the shade-tree way to diagnose this with anything other than a high end DMM with a frequency input (to count pulses or a small ociliscope) or the Subaru Select Monitor. Will ask Chris Debban for you tonight.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 12-20-2004, 03:47 PM
Yeah, it's been working great for a year and only quit yesterday.
The problem started when I was playing with the wire you're supposed to ground to fool the ECU into thinking you're in neutral and preventing high idle. The only problem with doing this is that you lose your cruise control ability. (on mine anyway)
The only thing that may have caused this was that I went to shift into 4th but may have been hitting R instead (slight grind). All the gears still work perfectly.
Old 12-20-2004, 06:03 PM
michael's Avatar
michael michael is offline
What Potholes ???
First eliminate vss2. with someone in the drivers seat unscrew vss2 and spin it with the ignition on if speedo jumps it's the vss2 gears.
Wanted: Steering Wheel
Old 12-22-2004, 07:53 AM
n00b on demand's Avatar
Any update worm?
Old 12-22-2004, 09:17 AM
RobSVX
What comes out with VSS2 ?
Hi,
So, when I unscrew my VSS2... what will come out with it ?
My Speedo,Odo,Cruise crapped out (engine codes show VSS2 and O2 and EGR all at once - weird).
If I remove, I wanted to check if its the speedo gear or just the sensor ???
Old 12-22-2004, 09:40 AM
mbtoloczko's Avatar
sans SVX
The speedo stopped working while you were driving the car?
Mychailo
Visit my locker
Old 12-22-2004, 12:47 PM
michael's Avatar
What Potholes ???
There is a T shaped protrusion from the bottom of the sensor, it is driven by an axle. It's kind of like how a flathead screwdriver fits into a screw. If you take it out you don't have to be afraid of stuff flying everywhere.
Old 12-22-2004, 01:09 PM
RobSVX
Great answer and pic !
Next question would be how do I get the 'shaft' out ?
Old 12-22-2004, 02:34 PM
michael's Avatar
What Potholes ???
If your problem is the speedo gears you have to drop the transmission and seperate it from the diff. to change the gear. I hate to be the bearer of bad news. I had mine done earlier this year and it cost me $400, a stripped stud and lug nut, scratched rim, broken antenna and a pair of clips for the H-6 engine cover. Whats worse is that it was one year after I had them put in a new diff. (a day after the warranty ended)
Old 12-22-2004, 03:58 PM
RobSVX
Mmm, that would not be a customer friendly design. Put a plastic gear someplace, you have to pulll the Tranny for ? Make me wonder if 'they' knew the Tranny would crap out soon anyway...
Thanks for the bad news, but I'll just use my Tach for the Speeds if the VSS2 doesn't fix it. No way I'm spending that much for a damn little gear !
Which controls the Speedo, Odo, and Cruise: VSS1 or VSS2 ?
Which is which mounted on the Tranny. I can find one that's seen thru the engine compartment, next to the tranny dipstick .
Old 12-22-2004, 07:53 PM
michael's Avatar
What Potholes ???
If i'm not mistaken it also messes up your ability to go beyond a 90/10 power distribution, it causes an error code no speed sensitive wipers or speed sensitive steering and you'll get hassled when you get your next inspection for mileage. Yes it is a poor design.
Old 12-22-2004, 09:29 PM
RobSVX
How 2 Check the VSS1 ?
I've seen how to check the VSS2, but how about the other at the tail shaft ?
The Trouble Code check threads didn't mention, a code for a faulty VSS1 that I could find ?
Old 12-22-2004, 09:49 PM
lee lee is offline
vss1 and vss2 error codes are 32 and 33 respectively.
Old 12-23-2004, 07:01 AM
RobSVX
Actually, Code 32 is for the O2 Sensor - Passenger side.
What's the code, if any, for the VSS1 ?
Thx !
