Old 07-27-2004, 09:30 AM
tracedog67
AC picture
Folks,
Can someone please post a pic of their AC compressor. On my '92 LSL I do not have a tensioner nut and the thing squeals like a pig at startup. When my wife leaves for work at 4:45 i'm sure the neighbors don't like to hear this thing.
thanks
Tdog
Old 07-27-2004, 10:27 AM
I will see if I can get one or I will take one today.
Old 07-27-2004, 10:39 AM
If you know that you need a nut, why don't you put one on?
Old 07-27-2004, 11:00 AM
tracedog67
AC picture
Earl,
I've got 2 nuts (don't laugh) that I can tighten down for the AC belt but neither one will take up the slack in the belt to allow it to tighten down to the point to eliminate the squealing. With the engine running I can see the belt is slightly loose with the compressor on. There is a center nut and a nut for sort of a swingarm below that one. Maybe i'm just plain ole missing a step mentally to tighten the belt?
Tdog
Old 07-27-2004, 11:29 AM
n00b on demand's Avatar
Ive got 2 nuts too but im not willing to give them up.
Old 07-27-2004, 11:40 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Let me see if i understand you right...
On the AC you have the nut that goes on the tension pulley itself, then a bolt that goes through the swing arm. Both those are 12 mm I believe. Also on the swing arm you have the larger bolt which is a 17mm (that the bolt goes through) but doesn't actually tighten a thing.
Let me see if we got how you tightened it down straight. You loosened the 2 12mm ones right? Then everything was loose. What you do then is get your 17mm deep socket and put it on the center and when you tighten that it moves the arm and takes up the slack on the pulley and belt, right? Once you have it pulled tight you tighten down the 12mm nut to hold the arm in place and then you take the 17mm socket off and tighten the 12mm bolt.
Just to confirm, is that what you have done and you are just missing that one 12mm nut that tightens the arm in place? Let me know. Thanks
~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 07-27-2004, 12:14 PM
Rotorflyr's Avatar
Let me guess, single, right.........
Old 07-27-2004, 12:51 PM
tracedog67
AC picture
Freakin' AHA! I don't have the 17 mm nut. I have the two 12 mm bolts. I literally took a wide blade screwdriver and shoved the swingarm over as far as possible and then tightened the lower 12 mm nut on the swingarm. Souds like I am missing the 17 mm nut. Someone please send me a simple pic of that little rascal.
Tdog (and soon thankful neighbors)
Old 07-27-2004, 01:36 PM
halistan's Avatar
Grand Poo-Bah
i'll post some pics tonight
I have some pics at home and we'll figure this out. I'm thinking though that the 17mm one should be there cause if i remember right its attached to the swingarm. I don' think it can be removed from it. I'll look again to make sure. I'll show you mine and how to properly tighten it down. I'll be home in another 3 hours or so and i'll try to get them up quick.
~Ray
Old 07-27-2004, 03:42 PM
Sonar's Avatar
Sonar Sonar is offline
Just took some pic's, but I don't know if we have the same layout ...
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 07-27-2004, 04:55 PM
A/C adjustment
T-dog, sorry it took so long to get back to you. The pix are in boxer6 locker under A/C adjust.
What halistan said was absolutely correct.
This shows the 12 on the lock-down bolt, and the 17 on the adjuster.
This shows the 12 on the bolt that you tighten first, while the other 12 is loose.
Old 07-27-2004, 05:20 PM
halistan's Avatar
Grand Poo-Bah
Thanks guys
Thanks for getting those pics. Those are exactly what i was going to post. See T, just loosen the two small 12mm bolts then use the 17 to tighten the belt and when you have it where you want it, hold it there and tighten the two 12's down. Should take all of about 60 seconds to get rid of the squeal
Hope we were all able to help you. Happy motoring
~Ray
Old 07-28-2004, 07:12 AM
tracedog67
AC picture
BEAUTIFUL! Thanks fellers. Now I have to check for that 17mm bolt when I get home tonight. I think I completely overlooked that puppy. After this fix I have to go get a few estimates after some guy hit the SVX on the lower driver side quarter this weekend. He backed right into my wife and he didn't have a rear view mirror.
Tdog
Old 07-28-2004, 08:20 AM
