Old 07-17-2006, 06:21 PM
Originally Posted by GreenMarineSVX
Dude, I know all about AWD and the effects of diffrent tire sizes... The question that I was origionally asking was what the widest tire is that will fit on the SVX wheel... My sexond question was if $400 is a decient deal on a set of excellent condition RX-7 wheels and tires... Also, How do ya tell if the RX-7 wheels are the reenforced ones or the unreenforced ones?
Thanks though
LAN has 255's on his SVX but you need rims with precise offset!
Check e-bay on RX7 rim prices. You'll never buy them new for that price.
Weigh them to determine which ones they are.
Old 07-17-2006, 08:16 PM
michael's Avatar
michael michael is offline
What Potholes ???
The stronger ones have a bell shape in between the bolt holes on the mounting surface. The lighter ones have squares.
Old 07-17-2006, 08:23 PM
immortal_suby's Avatar
Thread Killah
also the weight is different
see this thread
http://www.subaru-svx.net/forum/show...ght=rx7+strong
Locker Link
2015 BRZ Limited 6MT
Old 07-17-2006, 09:39 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chris,
The earlier, lighter 3rd Gen RX-7 rims weigh ~12# each, while the later versions weigh ~15# each. I have a set of each and wouldn't even think about autoXing with the 12# version. They will easily handle 245/45 tires and not rub (well, at least not with at least .5 deg of neg camber). I'm in the process of figuring out what it takes to fit 275/45s on all four corners (hot on the heels of Ben&Dave - except they've got the 275/45s mounted on stock rims with 1" spacers).
-Bill
p.s. $400 is a little high, think I picked up my 15# set for around $300 and the 12# set for $250 (they're chrome and the chrome is bad on two of them....)
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-18-2006, 06:33 AM
PDSides PDSides is offline
Old Guy
Originally Posted by BATMAN
front and back?
Sorry Green Marine - I was responding to the original question in this thread, not your inquiry about RX7 wheels.
Preston
Old 07-18-2006, 07:56 AM
mbtoloczko's Avatar
sans SVX
The widest tire that can fit on a given rim width is usually not the best solution. Tires are designed for specific rim diameters and widths. Stuffing a really wide tire on a stock SVX rim will cause vague turn-in response due to the pulled-in sidewalls, and maximum traction for that tire diameter will not be available because the cross section will not have the proper shape. For a 16x7.5" rim, the optimum tire size for good turn-in response and traction is probably either the stock size or maybe a 235/50-16 or 235/45-16.
Mychailo
Visit my locker
