Old 07-17-2001, 02:16 PM
Forcibly powerful
Originally posted by KEVINL
Also where do I find how to tap power mode so I can controll it with a switch.
I read it somewhere before and now that I need it I can't find it
Try Terry McLane's page Kevin
http://my.voyager.net/~tmclane/index.html#_Toc482082587
This switch is on mine as standard in Japanese Spec
Old 07-17-2001, 03:29 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Can you tell me where your power and manual switches are located? I want to see where I can put the power switch location.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 07-17-2001, 04:16 PM
Smile Power-crazy
Lwin
Sure thing Lwin
If you have a '92 owner's manual, on page 6-9 there is a diagram, OM-4779. It points to the Release button on top of your gear-shift console, just above Park.
Well, at the bottom of the console, just below 1, there is a slot, probably blank on yours. In that position I have a switch marked Power. It locks on the Power mode.
I have no doubt if you send off to some of the Japanese places, they could get you one from Subaru Japan. Paddlesnz would help with the info.
The lower button on the actual lever puts the car into Manual mode, but I suspect yours is the same. That is an anti-slippage mode for poor grip conditions, keeps the box in higher ratios.
Old 07-17-2001, 07:56 PM
Seraph's Avatar
I put my car in manual mode last night left it in first shifted out of first at 6500 and out of second at 7000
How was the car? Does it feel fast like it should?
<< If you have a '92 owner's manual, on page 6-9 there is a diagram, OM-4779. It points to the Release button on top of your gear-shift console, just above Park.
Unfortunately, I do not have a 92 manual. I have a 94 remember? thanks though. I think i know what you are talking about.
Lwin
Current SVX: NONE
Old 07-17-2001, 10:45 PM
KEVINL
it was fast but I still believe that power mode and a good high Rpm shift is still faster. for some reason i don't think using manu is faster I think its actually slower but it shifts at a chosen RPM where the auto mode varies rpm
Old 07-18-2001, 01:05 AM
Manual motion
In theory, shifting according to the box's "Manual" map must be slower, as it shifts up quicker.
With the box showing "Power" on the dash, if you physically shift the lever from 1 to 2 and so on, you should get a little more speed, if you don't break something.
Better to let the box make the changes I think.
