Old 02-18-2003, 01:55 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
New discs
I have just ordered a set of slotted brake discs from POTN with kevlar pads. Delivery expected in 7 days. I will let you all know what I think of them.
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 02-18-2003, 03:30 PM
Price?
Thanks Andy.
Let us know the price as well.
I had my fronts spun and shaved for the MoT. Works well, no judder.
The guy who did it was not pleased with the job. The surface finish was not as smooth as he expected. He says the disks are made of very hard metal. They do groan a bit if you bite the brakes hard at low speed, but no problems otherwise.
Next time they warp, I will have to buy new.
Old 06-06-2003, 12:51 AM
Andy's Avatar
The parts arrived on Wednesday. (How about that for service ) Will be fitted today. I will let you know how they are doing in a couple of days
Andy
Old 06-15-2003, 06:06 AM
Andy's Avatar
The new discs and pads are fitted and bedded in.
I am staggered by the difference. Of course there is no shudder, as expected, but the feel is incredible. You could almost disconnect the ABS, there is that much feel.
The braking performance is outstanding too. On a dry road, the front tyres 'twitter' on the ABS and the stopping distance has decreased measurably.
The pads are EBC Greenstuff. The operating temparature range is much wider than the standard pads. The feel from cold is about the same as OEM but lightenens as the brakes warm up. Through a series of downhill straights and sharp slow-speed corners, the old brakes would give up every time, and I have induced a degree of brake fade on all of my previous cars if I try hard enough. As yet, I have not managed to get the slightest bit of fade in these new brakes,despite my best efforts.
FYI the discs are EBCD731 Group N, and the pads are EBCDP6691
Available from www.performancebrakes.co.uk
Discs are £78 each and pads are £34 (pr) + VAT
Avoid dealing with Sejoc as they are nothing but trouble.
For all of you on the wrong side of the pond, they are also make in left-hand-drive versions from www.tirerack.com/brakes/ebc/greenpads
Andy
Old 06-16-2003, 03:42 AM
Thumbs up
Thanks for the run-down Andy.
Pun intended.
Interesting the pads are EBC Greenstuff. The boys in the Matra club, of which I am also a member, are also using these, and have reported good things about them.
I will buy a set for the front before my next MOT is due.
Old 06-16-2003, 11:18 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
For some strange reason I'm feeling as though I've been pun-ished.
Old 07-08-2003, 01:15 AM
Andy's Avatar
One month update.
Still really impressed. The 1st stop from cold needs a little more pressure, these pads seem to love heat!
The feel is a vast improvement over OEM, right from the initial bite until the stop. The brakes don't grab at all, making hard braking easier and more predictable, I still feel that ABS is no longer needed. (But I will keep it for the wife's sake )
There has been no sign of brake fade at all, which is unusual due to the number of hills etc around here.
I believe that the big difference is caused by the pads, although the new discs should be helping a little too. I will continue to keep you informed as they wear, but I am hoping for great things.
Andy
Old 02-04-2007, 08:10 AM
supertole's Avatar
supertole supertole is offline
AWD
Are pads different for LHD and RHD???
October 1994 SVX
Old 02-04-2007, 08:15 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
no..........
I'm thinking about getting ebc redstuff pads. Are they geared more towards racing-only or can they be used on the street?
Brian
Old 02-04-2007, 08:25 AM
supertole's Avatar
AWD
http://www.subaru-svx.net/forum/show...t=30308&page=2
October 1994 SVX
Old 02-04-2007, 08:29 AM
Ricochet's Avatar
I brought some ham.
One person says overkill, andy says they'd be good for heavier cars..?
Brian
Old 02-05-2007, 06:29 AM
Both comments may be correct at some level Brian.
For ordinary road use the Greenstuff ones should be more than adequate and have two advantages; they don't make brake dust; they are much more fade resistant and bite much better than standard pads.
As I understand it, the Redstuff are performance pads. As such, they will have a higher fade resistance and better temperature handling than the Green ones.
Now, as a drawback, they may not stop all that well until warmed up. This has little effect on the track, as "Warm" is the order of the day. On the road on a cold morning, they might not be the best.
I reckon the Green ones are hard to beat unless you are hammering your car everywhere and racing it and stuff.
My 2c
Old 02-05-2007, 07:52 AM
Ricochet's Avatar
I brought some ham.
thanks
Brian
Old 02-07-2007, 02:47 PM
Andy's Avatar
I now have Redstuff on my Forester XT and I think they are awesome. The 1st stop from very cold is about the same as OEM but from then on, they are much better that the Greenstuff for feel. (The 1st stop for me is from about 35mph.) When the 1st stop has been from high speed, the pads warm up during the stop, giving a very nice feel, which seems to compliment the tyre temperatures.
Andy
Old 02-07-2007, 05:45 PM
Sounds good Andy. the Forester is pretty heavy.
Brian, I got an EBC catalogue last month at the Autosport show in Birmingham.
The Redstuff pads are for heavy fast road cars and for competition use. So as Andy says, with a heavy and fast motor like the SVX they would be OK.
The pure performance and track pads are Yellow. These are the ones harder to warm up, and far from ideal on a road car.
I think Andy tried the Greenstuff ones before. So if Andy says the Redstuff are good for the Forester, I would have no hesitation putting them on.
