Old 07-14-2001, 04:24 PM
ehyde111
Question <REDLINE ATF> which one??
Which Redline ATF do you guys use? I see they have about 5 different kinds (synthetic, D4, High temp, racing, and C+) I got the D4 ATF -- it says it works for Dexron III, Dexron II, Mercon, or, Mercon V. Is this the right oil?
Thanks
Old 07-14-2001, 04:41 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: <REDLINE ATF> which one??
Thanks
I believe that most, who are using the Redline are using the "High Temp" grade.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-14-2001, 05:30 PM
zsvx
Re: Re: <REDLINE ATF> which one??
Which I never understood. I thought the point of all the coolers, etc. was to keep the temperature down to where it should be. I personally use the D4 ATF.
Old 07-14-2001, 08:15 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Re: Re: Re: <REDLINE ATF> which one??
Why?
Use the High Temp! The point of which, it doesn't break down as readily in case of high temperatures . . .
No offense, but even if you have a tranny cooler (which not all of us do), if you're going to spend the $$ on Red Line synthetic ATF, why not get something that will give you a little more protection from high temps?
Or is there something special about D4 ATF we don't know about?
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
