Old 11-10-2002, 06:36 AM
svxy's Avatar
svxy svxy is offline
Front Bearings
I know SVXes are known for their rear bearings, but has someone ever had problems with their front bearings. I have a noise that may be a bearing and its coming from the front. Where I work we have had Subby wagons for fleet vehicles and whenever a bearing has been replaced ( and there has been a quite a few, so don't feel isolated SVX owners) it's been a front one. Has anyone replaced a front bearing.
96 Red SVX 96,000 miles
02 Toyota Highlander
02 Nissan Altima
04 VW Beetle GLS
Old 11-10-2002, 01:54 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Front Bearings
I've heard of a few instances of front wheel bearings needing replaced, but not enough to consider it a "problem."
Usually, when a bearing needs to be replaced, it's the Right Rear.
Randy Johnson
Mike Davis -- at Reading VI
Old 11-10-2002, 03:59 PM
Re: Re: Front Bearings
Or the left rear, If you drive or the other side of the road.
For all the normal people.
Old 11-10-2002, 07:37 PM
Aredubjay's Avatar
Re: Re: Re: Front Bearings
OB.
Randy Johnson
Old 11-10-2002, 09:28 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Isn't that the same, considering that you're driving upside down also?
Old 11-11-2002, 02:39 PM
Yes I considered that, you would think it would make them last longer but I 've done one of each side.
Why is that so?
Why does the moon look larger on the horizon, than when over head?
Why do females like the shower 10 degs hotter than men?
So much to understand, so little time!
Old 11-11-2002, 04:16 PM
Aredubjay's Avatar
Why are there settings for perma-press on your iron?
Why is there a "hand wash" cycle on your washing machine?
Why do they make wax for "no-wax" floors?
Why do I spend hour, after hour, asking silly questions like this to people I only know via this silly network?
Randy Johnson
Old 11-11-2002, 04:27 PM
We should have a special forum, for these important questions.
yevraH.
Make it easy for the Beav.
