Old 11-03-2002, 03:59 PM
Angry Auto Seat Belt - No Go
First of all I did a search and didn't find what I was looking for. I am not saying it isn't there, I just can't find it.
Here is the problem. I replaced my battery. I have had the problem in my 1993 for some time now that the auto belt will only move forward when the key is on, and the door opens. Well, after I changed the battery, and the car is running, the seat belt will not move back when I close the door. In fact, it will not move at all any more. I don't know if this is just timing, or if changing the battery did something.
Any help would be appreciated. Being beltless does not help much. Thanks
Old 11-04-2002, 05:04 AM
svx_commuter's Avatar
There is a manual crank hole in the back seat on the wall and there is supposed to be a crank handle in the center console under the floor mat. At least you would be able to crank it to the rear position. and then use the shoulder belt
Old 11-04-2002, 10:51 AM
Thanks. I don't think I have one of those cranks, but I will check around for one. That may be what I have to do. I may try disconnecting the battery again, and see what that does.
(remembers that insanity is doing the same thing over and over again and expecting different results)
