Old 04-02-2019, 05:52 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
coilover adjustable suspension
just found this plus a whole lot more from Japan -
https://www.jauce.com/auction/n336071640
Old 04-02-2019, 06:53 AM
Re: coilover adjustable suspension
In the description it says they were damaged and repaired and missing an adjusting knob. Starting bid of over $600 CAD. No thanks!
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 04-03-2019, 10:55 PM
SURTEESS's Avatar
There is also another set - new in the same fitting. Check under www.jauce.com
