Old 08-25-2014, 03:22 AM
ShaneHobson ShaneHobson is offline
Plastic trim parts
I'm going to dump my first parts car in a month or two, once it's fully stripped out. Being the hoarder that I am, I will keep everything I imagine I could ever possibly need or want, or not.
But I will draw a line and bin some of the plastic parts and possibly the loom.
Before it goes to the scrapper, are there parts anyone here wants (or thinks I should keep) that falls into the category of highly likely to be dumped.
I suspect it's going to be a very short list, but I'm trying to head off the situation in a years time when someone says, "have you got a ....", and I've dumped it.
Old 09-12-2014, 03:05 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Plastic trim parts
Shane - see this link, maybe you should keep the little things !!!
http://www.subaru-svx.net/forum/showthread.php?t=63072
