Old 06-02-2014, 06:26 PM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
ABS Computer control unit - anyone??
Does anyone have a spare ABS control unit that sits under the passenger seat???? I need one urgently as mine got fried when heater core burst and drowned it with coolant!!
Old 06-02-2014, 07:15 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: ABS Computer control unit - anyone??
picture of old one please with some numbers for clarity.....
Old 06-02-2014, 09:11 PM
Here are a couple of photos of the unit - hope it helps in locating one.
Old 06-02-2014, 10:12 PM
'E''s Avatar
'E' 'E' is offline
I've got one
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 06-02-2014, 10:19 PM
SURTEESS's Avatar
see you can sell anything with a photo -
Old 06-02-2014, 11:59 PM
Originally Posted by 'E' View Post
I've got one
Have sent you a PM - please call me so we can work out details.
Old 06-18-2014, 08:18 PM
Do you by chance have one???? So far I have had 2 incorrect units sent and one identical but unfortunately on test came up with the ABS warning light so not good.
I am getting a bit desperate!!!
Old 06-19-2014, 12:10 AM
ShaneHobson ShaneHobson is offline
I have one here from my JDM parts car.
Various stickers on it read :
48 RHD 4WD AT
Nippon ABS 26720pa010 (probably the Subaru part#)
170-0701 (probably the serial number)
Condition unknown, but I may be able to test it in my DD.
I've pulled the cover off and it looks clean & tidy inside.
Any idea of it's value ?
Old 06-19-2014, 12:14 AM
Thanks Shane - that is the part number of the unit I need. I am in the process of bidding for one from Japan which will cost me just over $100 landed but will probably take another 2 weeks. If you can plug it into your car just to see if no ABS warning light is triggered, we'll at least know whether the unit is OK. At least that way I know where there is one.
Thanks again for your help!
Andrew
Old 06-19-2014, 03:20 AM
Probably not until this weekend. I assume I need to remove the passenger seat then follow my nose from there.
No error light on the dash or do I need to also check the light hidden under the passenger seat ?
Old 06-19-2014, 10:34 PM
The ABS warning light on the dash should be enough. Don't go to any trouble at this stage Shane - I'll let you know if we need to go to that stage. many thanks for your help.
Old 07-16-2014, 08:21 PM
All good and car back on the road! Many thanks to Shane Hobson for your help with the unit. Cleaning out the coolant from the carpet is a hell of a job and don't recommend it to anyone!
Old 07-17-2014, 02:01 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Hey everyone.
I am in the exact same predicament. Heater core blew and fried my ABS. Are there any more units available?
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 07-17-2014, 03:55 PM
scoobymal's Avatar
scoobymal scoobymal is offline
My yellow car got flooded inside (sunroof drain tubes) it filled the ABS unit with water, it put the warning light on the dash. I dried it out and sprayed the circuit board with WD40, worked perfectly and has done for the last 4 years, worth a try.
Mal
Old 07-17-2014, 10:03 PM
'E''s Avatar
'E' 'E' is offline
I want a yellow svx lol
93 black SVX
95 bright red SVX
