Old 05-04-2014, 11:44 PM
ShaneHobson ShaneHobson is offline
Need CV joints ?
I'm helping out an SVX owner in Tokoroa who needs a CV joint for his car.
Searched the parts books, trawled Hansen's and found they're about $250.
Went into a SAS Group outlet here in Hamilton and they came up with three options, all less than $100 each.
They seemed confident they would work.
http://sasgroup.co.nz
Could be worth a crack next time you need suspension parts.
Old 05-05-2014, 12:53 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Need CV joints ?
Shane,
let us know how you go with the CV stuff - is it for a "normal" SVX or 4WS model ?.
Just doing a visor fix for my car - The JDM/Aus/NZ visors are different p/n than the ones from USA, the internal material & mechanisim is different, but my fix could be done for both.
I will finish documenting it over the weekend.
