Old 05-14-2013, 12:41 PM
shotgunslade's Avatar
WTB: Hood struts and brackets.
Need set of hood struts each with both frame and hood brackets. Prefer struts be "dead", as I will use them for a fiberglass hood.
Old 05-14-2013, 07:34 PM
Dan sr Dan sr is offline
Re: WTB: Hood struts and brackets.
L/R hood brackets - $60.00 plus cost of shipping $25.00
partstogo@gmail.com Dan sr.
