Old 02-05-2013, 03:18 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
VSS2 Harness Wanted
I am looking to buy a harness to the vehicle speed sensor 2. It is for a 1995 SVX L AWD. The wires broke off at a very crucial point of the harness and its nearly impossible to solder them back together. This is what I am looking for ----> IMAG0146.jpg
Thanks
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 02-05-2013, 05:01 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Re: VSS2 Harness Wanted
Worst case scenario you can push the pins out of the connector, remove the old wires, and solder new wires on to extend to a place where you can more easily fix things. A paper clip will usually do the trick, but failing that, a large sewing needle will work to unhook the little clips on the pins.
Old 02-05-2013, 06:56 PM
Originally Posted by Svx95 View Post
I am looking to buy a harness to the vehicle speed sensor 2. It is for a 1995 SVX L AWD. The wires broke off at a very crucial point of the harness and its nearly impossible to solder them back together. This is what I am looking for ----> Attachment 17034
Thanks
I feel like you didn't check my post in the other thread...
Old 02-06-2013, 08:58 AM
I think I have a few with about 6-12" of wiring from ones I yank from the pick n pulls. I'll have to check.
Old 02-06-2013, 09:27 AM
dbarnblatt's Avatar
Agree... easy repair. Fixed a connector on our Mazda a few days ago where the wires broke off right where they meet the connector. Took the pins out, soldered new wire, and connected back up. Took about 20 minutes.
Old 02-06-2013, 10:15 AM
Svx95's Avatar
eg33svx95
Yes, I failed to check...woops. sorry!
Sam
