Old 11-09-2012, 11:09 PM
gjhumphris's Avatar
gjhumphris gjhumphris is offline
Driver's Door Window Switches
The power window switches cluster in my driver's door has come loose from the "woodgrain" armrest insert. The end closest to the door handle has dropped about 1cm, but the top part nearest to the window lock button seems to be attached still. Does anyone know how the other end is attched? I unscrewed the 5 screws to get the door trim off to fix it, but it seems stuck at the top, so before I break something, I thought I'd check how the switch cluster clicks in first. Thanks!
Old 11-10-2012, 01:39 AM
flamestone's Avatar
flamestone flamestone is offline
Re: Driver's Door Window Switches
I've had my door trims off to refurbish all switches, and since I don't recall exactly how it all came apart, that means there probably wasn't any special trick to it.
If something is stuck, maybe there's an existing non-original repair under there?
Old 11-10-2012, 02:34 AM
gjhumphris's Avatar
OK. Had another go and all came off nicely - I must've been too gentle - Just didn't want to snap anything!
There are 3 screws holding the switches in place, but unfortunately 2 are broken. Should be able to fix it though with a bit of epoxy.
Rest of the door, speaker, window rollers, etc looks in mint condition luckily.
Thanks!
Old 11-10-2012, 07:04 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Hi Grant.
My left rear window just stopped working. We should talk SVX, as the SVX will keep you on your toes!
Call me soon man. 0403 877 740
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
