Old 03-25-2012, 11:43 PM
xis99 xis99 is offline
Service Required
hi all,
have moved to melbourne. went for 170,000k service was told I had leaks from
1) timing case seal
2) rocker cover gasket
3) auto trans sump
4) extensive housing seal
5) trans cooler lines to radiator.
I am shell shocked, as i don't see anything on my driveway.
so need to get 2nd opinion. any suggestions as to whom might know what they are talking about and h ow bad these are ?
TKU
Old 03-26-2012, 03:26 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Re: Service Required
Hello and welcome.
Unfortunately, the mechanic may be right. These sexy, modern looking cars are now 20 years old and things start to either leak, rattle, crunch or go bang.
I recommend that you search through these forums and ask some more questions before you spend any money though!
I am in NSW, but there are members in Melbourne that may be able to help.
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 03-26-2012, 08:32 PM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
Well join the club!!! I am in the process of getting my rocker cover gasket replaced, sump and diff resealed and will wait for the major service when we do the timing chain to do some of the other leaks! Mine has 165K on the clock....
Old 03-27-2012, 02:16 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Smile Re: Service Required
Mine has 136,000 kms on the clock & has only ever dripped oil from between engine & gearbox seal - mechanic said it was not worth touching since it was only about 2 drips per month!!
Old 03-27-2012, 05:11 AM
steamer99's Avatar
steamer99 steamer99 is offline
Originally Posted by xis99 View Post
hi all,
1) timing case seal
3) auto trans sump
TKU
Hi, I do not know if they have regulations regarding leaks in Australia, but if not personally, I would just watch the levels and change the gaskets as other work needed to be done.
1) Timing case seal, at 170K get ready to change the timing belt (recommended every 100K and the oil will reduce the life of it), do the full job: cam seals, water pump, idlers, tensioner, belt, timing belt cover seals.
2) Rocker cover seal, just a mess when it gets worse, not required until it bothers you
3) Auto trans sump, change the gasket next time the transmission fluid and filter needs a change.
4) extensive (extension?) housing seal, same as #2
5) Trans cooler lines to radiator, this is the one that I would track down first since (personally I destroyed a transmission in my truck this way) if it is a rubber section getting weak and weeping that section should be replaced before it breaks, but if it is just a fitting may be solved by tightening it up.
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
Old 03-29-2012, 06:14 AM
'E''s Avatar
'E' 'E' is offline
I'm going to a wedding in melbourne this weekend if you want me to have a look
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 04-05-2012, 01:34 AM
Once again ,
thanks 'E' for having a look at my car.
getting another check done after long weekend. the tall 1 thinks he should let the pro's do it .
Old 04-05-2012, 02:55 AM
'E''s Avatar
'E' 'E' is offline
Lol probably a good idea and it was my pleasure
93 black SVX
95 bright red SVX
Old 04-12-2012, 05:21 AM
OzBloke's Avatar
OzBloke OzBloke is offline
Gday TKU
I have a great mechanic in Ringwood who looks after all my cars including the SVX. If you want his details just let me know.
Cheers
Col
1992 SVX 120,000kms
STi Rims, Dents removed, Respray, Trans cooler
Old 04-25-2012, 05:30 PM
Col,
i would appreciate the name & address of mechanic. ringwood is not too far .
who takes a car apart , then tells you they don't keep that tiny little rubber part .
grrrrrrrrrrrrrrrrrrrrrrrrrr
joann
Old 04-26-2012, 04:50 AM
OzBloke's Avatar
Hey Joann
Luke is my mechanic. Tell him I recommended you and he should look after you. Details are here http://www.adrvic.com.au/
Cheers
Col
1992 SVX 120,000kms
