Old 02-27-2012, 07:17 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Mobil 1 High Mileage 5W30 Used Oil Analysis
The Purolator One filter is 30165
That is a Purolator Classic, not a Pure One.
Tony
Old 02-27-2012, 08:06 PM
Sorry, Tony.
It should be the Purolator Premium Plus 30165. Not that it says in my cr long enough to make much difference.
Old 02-27-2012, 08:24 PM
Thanks, guys. I ordered two of the bosch ones off of amazon.com, because that's all that was left in stock.
Old 03-18-2012, 08:16 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Ok, so I did the 5qt of 5w-30 HM and 2 qts of 0w-30 Extended Life whatevers..
and now on startup, I have a very brief, one second knock..like it goes KNOCKKNOCK and done.
Should I be worried? Or is it just knocking because of the lack of oil on startup?
Old 03-18-2012, 09:01 AM
Does it knock every time you start,
or just the first time that you started it after the oil change?
Old 03-18-2012, 03:08 PM
Chuckls's Avatar
Designated Asshole
Every time pretty much. Depends on the frequency of starting
Old 03-18-2012, 05:37 PM
What oil filter are you using and does it have a check valve in it? Even some of the ones that do are known to sometimes slowly leak oil through the valve.
Tony
Old 03-18-2012, 05:41 PM
Chuckls's Avatar
Designated Asshole
Bosch Distance Plus.
I wanted Purolator classic, but Adv. didn't have it
