MAF for ReNt.. ?
Can I borrow a GOOD MAF for $50 plus shipping both ways? Got an EXTREE?? [+Deposit, of course, in case I die.. before returning your rental.. Hmmm?]
To diagnose my *%#* SVX! Ha! Running bumpy.. sometimes .. after re-soldering my MAF.. ?? Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 01-13-2012 at 06:34 PM. |
My original MAF is sitting alone in a drawer, pondering its existence the last couple years.
I'm not terribly interested in going back and forth with it but if nothing else turns up for you give me a heads up.
Re: MAF for ReNt.. ?
So far.. the symptoms are CrAzY! I did re-solder of MAF.. Now, it doesn't do the intermittent crash.. but, does very jerky low speed accelerations???
Does original mean you replaced it.. cuz wasn't working?? WELL, thanks for responding.. I'll check the TPS as some have suggested, but it doesn't make sense that the TPS wud SUDDENLY malfunction .. after I "fixed" the MAF.. ?? Seems to me.. must still be MAF?? Thanks, Jim P.S. Obviously, if it worked.. I'd want to buy it. How much to buy?
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
My maf works fine, it's been pulled because I went Z32 and I have no use for it.
I would sell it for a minimal cost, haven't given it much thought.
Still can't tell if it's the MAF! Checked the TPS last nite.. seems ok.. BUT, runs about the same .. with or without the MAF connected now.. ??
Sorry.. wats Z32? Thanks, Jim P.S. If your price is low enough.. I guess I can just get yours.. and KEEP it .. if not needed??
ECUTune stage 2.
Z32 is a generational designation given to Nissan's 300ZX. It was preceded by the Z31. The stage 2 kit requires a Z32 maf and SR20DET injectors, so I just refer to the upgrade as Z32.
IC .. Thanks for the info .. I'll keep checking things.. Still runs OK at high speeds, but jerky on low speed acceleration ?? Idles OK .. .
Thanks, Jim
Did you try the MAF spray cleaner?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
Yah! .. Sprayed it when I took the MAF out .. and re-soldered it. ???
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 01-18-2012 at 07:09 PM. |
