Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 01-11-2012, 09:51 AM
apkarian100's Avatar
apkarian100 apkarian100 is offline
Rear Side Marker Connector Question
Hey guys, I'm doing another LED conversion, with the rear side marker lights. I made the modules, yet I don't have a car to test them, so I'm lost as to which side is positive and which is negative on the connector. LEDs are polarized, so they only work one way. Here's a pic of the connector:
Does anyone want to test the connection with a multimeter, or tell me which pin is positive and negative? I would greatly appreciate it if someone could help me out on this.
Thank You
Old 01-11-2012, 10:11 AM
Re: Rear Side Marker Connector Question
Just match your connector to the matching plug with the wires.
It is a two wire plug. the black wire is ground and the pink wire is the hot wire. This ties directly into the existing tail light circuit, which uses the same two colors.
You could just tap into the wires of your LED tail lights.
The complete wiring schematics are in FSM 6-3, page 53. You can see it and download it HERE
Old 01-11-2012, 10:12 AM
92 SVX 92 SVX is offline
I dont think he has a car to match it up with
That is what I found 2 mins ago
Old 01-11-2012, 11:13 AM
Yah, I don't have the rest of the harness, but this pic is helpful. Thank oyu!
Old 01-11-2012, 06:08 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Smile Re: Rear Side Marker Connector Question
here in New Zealand we did not get this as an option - our "side markers" are only "side reflectors", they do not come with marker holes in them, or the bulb & holders.
Just another quirk or option that I thought I would share with you - I have already converted mine to the USA type side marker, but would like a second spare set as a back-up (the bulbs + bulb holders + wiring connector + side marker).
Can anyone help me - I have seen a few on ebay, but it is either one side or the other - normally without bulb connector & wiring connector.
Thanks in advance
Stephen in Auckland, NZ.
surteess@xtra.co.nz
