Grey vinyl/cloth seat back skin
Does anyone have a used driver (or passenger) seat back skin in Gray vinyl/cloth.. in good shape.. I could buy? In fact, passenger might be better.. because most are in much better shape than the driver's side. [I think both can be used on the driver's side.. right??]
Mine's badly torn on the left side (Yes, FaT!) I started to get one (ALL SKINS) from a member in April 2011, but he disappeared.. Ha! Help! Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 12-06-2011 at 05:19 PM. |
Re: Grey vinyl/cloth seat back skin
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine) Honda FT500 Ascot [Red] |
If he only needs the actual seat covers, just take them off and send them, it's much cheaper on shipping and gets the job done just as well.
Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 12-15-2011 at 06:02 PM. |
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
She doesn't wanna take the skins off. I can understand.. .
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
James,
Several years ago I purchased a cloth SVX seat from another member. I stripped it down so I could replicate the upholstery and make my own custom seats. I never had the time to finish my project, but I still have the pieces of the seat. I don't remember if I removed the "skin" or if it's still attached. I will look tomorrow and let you know. I just remembered this random SVX seat I still have sitting at my parents house. I'm assuming you mean the back piece of the seat...not the cloth seat material itself...correct?
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
I mean the upholstery skin your back rests against while you are sitting in the seat (instead) of the part your butt rests on.. .
It is cloth and vinyl.. .
It's a little ripped as you can see, but it's cloth and ready to go!
Sorry.. mine are med grey vinyl/cloth.. and drivers seatback is ripped/worn on the same side. Thanks for your effort. Maybe I shud put a pick of mine.. the one I need to match.. .
There is only one color of that type of seat.
Here is my damaged grey vinyl/cloth driver seatback.. which I need upgraded with a good condition matching skin.. .
Doesn't wanna attach photo from my cp.. ?? I'll try.. .
Here it is .. FiNaLlY!
If that is the only problem, there are people that can do repairs on that stuff. a guy came to my house and fixed a recliner and you could never tell.
THANKS.. I'll check it out!
Thread Tools | |
Display Modes | Rate This Thread |
