Old 10-03-2011, 05:47 PM
spleen_merchant spleen_merchant is offline
Manual swap in Aus?
Does anyone have any experience getting a manual swap performed here? Can someone recommend a mechanic/performance shop who will do this sort of work?
Cheers,
Jeremy.
Old 10-03-2011, 08:51 PM
93tzlegacy 93tzlegacy is offline
Re: Manual swap in Aus?
Cheers,
Jeremy.
while ive never done one, I do own a manual converted SVX and im pretty sure i could replicate it . its quite involved and there is a bit of fab work required with a gearbox mount and a tailshaft, you also need to modify the firewall for the clutch mount, relocate wiring, modift the TC and starter wiring among other things.
Old 10-04-2011, 12:23 PM
I have the whole instructions for the swap someplace if you wold like a look see.
Old 10-04-2011, 07:18 PM
i would like to see/get a copy of your instructions conn
Old 10-04-2011, 08:14 PM
I think the plan's going to be to order one of the smallcar basic kits from the US and source the rest of the parts here.
Old 10-04-2011, 11:21 PM
This is the manual swaper's Bible.
http://www.subaru-svx.net/photos/fil...k369/19802.doc
Old 10-05-2011, 01:23 AM
spleen merchant ive heard the small car kits are not the best of quality
and my dad is a welder fabricator and 30+ yrs exp mech as long as we have a fair idea of what needs to be done im sure we can modify whatever needs to be modified ,
thank you oab_au i shall bookmark that link
i still need to find a cheap trans etc or a cheap donor car to get everything il need to do it (hopefully i can find one fairly soon)
Old 10-05-2011, 07:48 AM
I have not heard good things about the small car kit...
Old 10-05-2011, 05:08 PM
You also need to know that our crossmember is different , and our tailshaft is shorter than the US one. You also have to use a US or JDM front Hall Effect speed sensor, that you will have to supply power to, and wire the sensor's output to the speedo.
Old 10-05-2011, 05:15 PM
Also, this other how-to may be quite useful. It might not be in the how-to docs anymore.
Old 10-05-2011, 07:45 PM
you can use any subaru 3 wire speedo drive, the one in my car is fro man aussie 05 wrx.
Old 10-08-2011, 05:20 AM
Dessertrunner's Avatar
If you go to a 6 speed the tail shaft is the same you only need to mod it when you go to a five speed.
Tony
Old 10-08-2011, 06:43 AM
Tony
i guess il look for a 6 speed wreck then so its a bit easier to put it in ... and i would prefer a 6 speed over a 5 lol
Old 10-08-2011, 10:21 AM
Unless you're planning to get some more power out of the car, then a 6-speed isn't really worth the extra cost. It's also a lot heavier, and the older ones that you're more likely to find for cheap will have shorter 5th and 6th than is ideal in a highway driven SVX.
Not to knock the 6-speed, it's great, but there are trade-offs.
Display Modes Rate This Thread
Rate This Thread:
