Old 06-30-2011, 01:53 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
92 and 94 parts for sale
I have many parts from a black 92 and a green 94.
I also have a complete wiring harness form the 94.
Just some of the parts include:
- Tons of body parts including all head lights & tail lights
- Sensors - including MAF, IACV, TPS, Intake solenoids,
Cam/Crank angle sensors, etc.
- Mechanical - Cam/Crank shaft(s), brakes and calipers, ABS control units,
other brake parts, etc.
- All interior sensors and components.
- Automatic Transmission parts
- Lots of suspension parts
Let me know what you need.
Thanks,
Marc
Old 06-30-2011, 02:11 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: 92 and 94 parts for sale
Thanks,
Marc
Do you have a door check that doesn't click.
Tony
Old 07-01-2011, 01:18 PM
svxcuseme's Avatar
5 speed 4 sure
Yes...but how do I know if it clicks? Does it do this when shutting the door or opening, or am I missing it entirely.
Old 07-04-2011, 04:51 PM
svxcuseme's Avatar
5 speed 4 sure
Old 07-04-2011, 04:56 PM
I'd like a pair of bad rear struts if you have some. No springs/topmounts, just the strut housings themselves. You aren't that far, so shipping might not be so bad. Struts themselves bad, but housings in ok shape, for coilover conversion.
Old 07-04-2011, 11:20 PM
Obewon Obewon is offline
Any grills ?
92 SVX, Ebony Mica 186,000 kms
92 Mercedes Benz 300CE, Arctic White 187,000 kms
Old 07-05-2011, 07:52 AM
longassname's Avatar
Just some dude.
The automatic transmission parts:
What happened to the transmision that it is parts now?
I could use the entire rotating assembly minus the forward clutch drum and the reverse clutch drum. Those two drums are the big parts--everything that stacks between them, what I need, will probably stack inside eachother into flat rate box.
I could also use a valve body.
Old 07-05-2011, 11:12 AM
svxcuseme's Avatar
5 speed 4 sure
icingdeath88 - PM sent
Obewon - I have 3 or 4 waterfall grills but not the newer style.
longassname - The trans is sitting complete outside the car. I planned to break it down to get the Diff, pinion, & speedo gear. I can get those parts you need as well once I get it apart. How fast are you looking to get these things and what do you think is a fair price?
Old 07-05-2011, 11:17 AM
Yes, it makes a loud clicking noise when opening and closing the door.
Tony
Old 07-05-2011, 04:36 PM
Just some dude.
$250 and I would need them soon.
Old 07-06-2011, 05:55 PM
Chip Hutchinson Chip Hutchinson is offline
Hello, do you have a master window switch pack? If so,
how much including shipping to Spokane Wa.?
Old 07-07-2011, 05:11 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Is your TPS in good working condition?
1995 Subaru Svx L / AWD
Old 07-07-2011, 09:19 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
PM sent about front struts for the '92
Jared
1992 dark teal SVX LS
Old 07-07-2011, 03:00 PM
svxcuseme's Avatar
5 speed 4 sure
longassname - Okay...I can pull them this Saturday and have them shipped on Mon. Is that fast enough?
Chip Hutchinson - Sorry...those are always the first items to go!
msvx95 - I have a couple. Will measure them on my make shift scale and get back to you this weekend.
FYI - I know they are expensive but I bought a new one from the dealer.
LastSVXintheChi - I can't say whether they are good or bad as I've never driven either parts car. I suspect they are not in good condition given the age.
Old 07-08-2011, 01:52 PM
Alrighty thanks for the straight answer!
Jared
