Old 03-22-2011, 11:10 AM
zaueugen's Avatar
zaueugen zaueugen is offline
cosmetics.. problem with front
there is a slighter bigger gap between the left headlight and corner light when compared to the right one... it looks bad and i dnt know how to fix it?
Old 03-22-2011, 01:43 PM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Re: cosmetics.. problem with front
Have you take a look on the screw on top of the headlight that hold the corner light? If this just happen maybe you missing this.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 03-22-2011, 02:46 PM
zaueugen's Avatar
no its not that.
Old 03-22-2011, 05:22 PM
I you take out the center grille, you will see the two bolts which hold the headlight in.
If you take out the turn signal assembly, you will see two more bolts which go into the side of the headlight. Loosen these a fair amount.
Go back to the bolts in the front . Loosen them and try to slide the headlight to the side as much as you can and tighten them snugly. Then reinstall the turn signal assembly to see if the gap is tighter. If it is, tighten the two front bolts completely.
Take out the turn signal again and tighten the two bolts on the side just enough to keep them from moving; don't tighten these too much. Reinstall the turn signal and the grille.
Once you reinstall the center grille you may have to slide it somewhat to even the gaps between the grille and headlights.
Of the above procedure does not produce the desired results, simply elongate the two mounting holes in the front to allow the headlight to slide a little. I did that on my Polo.
Old 03-22-2011, 06:31 PM
zaueugen's Avatar
i took out everything out, ill try to mess with is see what i get.
Old 03-22-2011, 09:01 PM
Just follow my instructions and you will be fine. Was the car ever in an accident which involved the front end?
Old 03-23-2011, 12:44 PM
zaueugen's Avatar
yes, i hit a suv softly, the hood went a little under the bumber of the suv.. the hood got slightly offset, which i guess the headlight did to. but u cant see that the headlight is offset its not really visible... except for that little gap.. i still didnt fix the hood cuz its not very visible, but i will
Old 03-23-2011, 02:43 PM
Posting unclear statements with a lack of photos will yield few answers to your vague inquiry.
Old 03-23-2011, 03:19 PM
Green1995SVX's Avatar
Somebody's having a bad day.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-24-2011, 09:20 PM
zaueugen's Avatar
haha i know i thought the same
