Old 02-09-2011, 09:13 PM
sheldonmaul3 sheldonmaul3 is offline
chip installation
I just recieved my ECUTUNE chip
i had planned on installing it myself because it is a plug and play chip..
however i think it may be smarter for me to have a professional do it..is there anything i need to tell them before i let them dive into my car??
thanks
Old 02-09-2011, 10:18 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Re: chip installation
Honestly, there is no reason to not do it yourself. Once the ECU is out, it takes about 5 minutes to get the cover off, install it, clip the resistor if needed, and put the cover back on.
Old 02-09-2011, 10:34 PM
You're almost guaranteed to do a better job than anyone you could hire to do it. They'll get frustrated and only reattach like 1 or 2 bolts. You will need long skinny fingers, a 10mm wrench, and a screwdriver. I think that's it. It's really easy, post here if you need help. It'll help if you remove the the two thingies that sit under the ECU. More room to wiggle.
Old 02-09-2011, 10:58 PM
im a decent mechanical guy..but when it comes to wires and stuff i get confused and dont want to ruin my car..
im most worried about clipping the resistor..it has to be done a super careful way right?
Old 02-09-2011, 10:59 PM
theres so many bundles of wires underneath near the ECU i couldnt even see the 3 bolts to undo!
i really wanna do it solo but i dont want to ruin my car at the same time
Old 02-09-2011, 11:04 PM
Clipping the resistor is easy, I promise. It sits up enough from the circuit board that you're not too likely to mess anything else up. Just use a small one of this type of snipper tool: http://www.acehardware.com/product/i...ductId=1294466 or something similar.
Old 02-10-2011, 04:21 AM
Yeah, if I can do it anyone can. It is somewhat of a pain in the ass to get the bolts holding the ECU out but it is not too bad.
Old 02-10-2011, 09:24 AM
The guys at motorsport warehouse said tO crush the resistor..so do I crush it or snip the wire attatching It to the circuit board?
Old 02-10-2011, 11:01 AM
Hi Mr. Penguin!
You're thinking of two different things- one is the 'ECU noise bead' crush TSB and the other is the J1 resistor you remove completely, activating the 2nd EPROM slot on the ECU board the Stage 1 chip installs into. Both the J1 resistor and the noise suppression bead can be seen in photos here:
http://www.svx-iw.com/svxiw/article/?article=143
You can read the Stage 1 chip install instructions here:
http://www.ecutune.com/SVX-Stage-1-Instructions.pdf
Read those install instructions and most of your questions will be answered.
Old 02-10-2011, 12:39 PM
Here you can see the nuts that hold the ECU/TCU, and the things you can move out of the way to get to them easier.
Is there any point in doing the bead crush mod when the ECU is apart?
Old 02-10-2011, 03:16 PM
immortal_suby's Avatar
Thread Killah
Sheldon, there are a few members in your area. I'm sure a 6 pack could convince one of them to give you a hand with this mod.
Locker Link
2015 BRZ Limited 6MT
Old 02-10-2011, 05:47 PM
Thanks man
i have alot better idea what to do now
im going to remove my ecu right now then i will post a pic of the internal stuff and maybe you can help me from there
I appreciate the help
Old 03-03-2011, 12:58 PM
dromano's Avatar
dromano dromano is offline
Does anyone have a picture like this of the front wiper control unit? I can't locate it, apart from the fact that I'm too old to twist myself up under the dash.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
