Old 01-20-2011, 02:41 PM
Invisible avatar
Question Who's driving with original parts?
My mental exercise with a decade's worth of SVX companionship has prompted me to ask this question. With all the grief found within this site dedicated to failure, or what's about to fail, I got to thinking; yes, dangerous, but nonetheless - What HAVEN'T you replaced? I'm not concerned with the stuff that every car out there needs to keep rollin'; brakes, rotors, tires, batteries, belts, etc. - just the plastic & metal stuff that might seem to be "prone to failure, because it's a dam' SVX".
While this sort of bragging emits thoughts of "The kiss of Death", I'll begin the list because I'm not superstitous. (Knock on wood).
As far as I know, or at least in the last 10 years, my '92, build date Jan. 92 at 150K miles still has the original:
Engine, radiator & fans, alternator, master & brake cylinders, ABS module, coils, fuel injectors, climate control system & A/C compressor, stereo (front door speakers need help), power antenna, power seat, auto-belts, sun roof, all lighting except a couple dash LEDs, exhaust system, drive train, suspension, struts, & wheels.
And....the infamous slush box, while replaced over 10 years ago, has hummed along for close to 90K with one power flush 50K ago.
If I've overlooked something else pertainent, it's probably because it's still working.
Anyone else dare to do some boasting?
Ron (now gritting teeth).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 01-20-2011, 03:26 PM
SVX_MY_BABY's Avatar
Re: Who's driving with original parts?
Engine, radiator & fans, alternator, master & brake cylinders, ABS module, coils, fuel injectors, climate control system & A/C compressor, stereo, power antenna, power seat, auto-belts, sun roof, all lighting, exhaust systemOrigional muffler, drive train, suspension, struts, & wheels.
And....the infamous slush box, replaced under warranty in '96 I think, but it's getting weak (not the tranny's fault. It's a long story.)
Have replaced the red items from your list, plus the gas line. Drivers belt doesn't always retract. Could have lived with the suspension but it just wasn't like it was when new.
Not bad for a June '91 build. It's not my main driver, but I do drive it all year. Less in winter.
Peter
Old 01-20-2011, 03:31 PM
Gamesy's Avatar
Gamesy Gamesy is offline
removed the resonator
changed the transmission to 04 wrx 5spd
injectors/maf/ecutune chip for stage 2
everything else is stock
Old 01-20-2011, 04:07 PM
immortal_suby's Avatar
Thread Killah
At 282k mine still has the original.............drum roll.............rear wheel bearings!
Locker Link
2015 BRZ Limited 6MT
Old 01-20-2011, 04:18 PM
Invisible avatar
You must be playing the stereo REALLY loud, Matt.
'01 Miata SE - 79K
Old 01-20-2011, 05:50 PM
Green1995SVX's Avatar
Everything on my SVX is original except for:
brake pads and rotors, battery, tires, CD player, front door speakers, fuel lines over the gas tank, and front axles.
I'm on the original transmission, and original wheel bearings.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-20-2011, 07:08 PM
Manarius's Avatar
Manarius Manarius is offline
At 191k miles: Engine (headgaskets), radiator & fans, alternator, master & brake cylinders, ABS module, fuel injectors, climate control system & A/C compressor, speakers, power antenna, power seat, sun roof, all lighting (replaced some bulbs), exhaust system (resonator delete prior to my ownership), drive train, suspension, struts, transmission, security system, fuel pump.
Replaced: Wheels/wheel bearings, coils, headlights, negative lead (rusted out), radio, original tail bar (broke original during bake).
-Jason
-Obi Wan Kenobi
Old 01-21-2011, 11:09 AM
dcarrb dcarrb is offline
Having put some 80,000 miles on two cars, here's what's been replaced, in addition to scheduled maintenance/expected wear items:
AC compressor (both cars), alternator (both cars), wheel bearings (both cars), radiator (teal), steering rack (silver), power antenna (both cars), rear strut mounts (silver), an ABS sensor and 2 tone wheels (silver), cam cover seals (teal), front sway bar bushings (both cars), stereo speakers (both cars, doors only).
The transmission in the silver SVX was apparently replaced by a previous owner @ just under 70,000 miles
I'm probably forgetting something.
dcb
Old 01-21-2011, 12:21 PM
Bobb Bobb is offline
Hi everyone, Yes the tranny god dumped on my transmission a while back. Nothing new there. However in preparation for our trip to Washington State to see Earl last summer, I had all the pulleys and the like replaced in the front of the engine. I also had the TPS and throttle cable replaced. And surprise, the car ran much better. Everything seemed much crisper and seat of the pants quicker. I was quite surprised. I also had new ignition wires put in. Any of these things might have had an effect in improving performance. While I had the transmission out I sent the Radio/CD player out to Panasonic and had them look it over and fix whatever they could and clean it up. The thing we all tend to forget is that some items on and in a car will die of old age. Not just from high miles. Take a look at your seats and transfer that vision to all the other items in the car. Well enough of this thinking cap stuff. I'm off to do some shopping. The high temp today is going to be around 17 degrees. Take care, BOBB
Old 01-21-2011, 03:15 PM
It's easier to list what original parts have failed.
alternator (twice, probably due to coolant leaks)
transmission
one headlight
that damn driver's side window clip
some mysterious part of the ABS system (could be the harness, again due to moisture)
radiator
rear top mounts
fuel pump.
That's about it. Everything else is either stock or was replaced for reasons other than defects or failure, i.e. vandalism.
Despite all the problems talked about here I think these cars are still rock solid.
Old 01-21-2011, 09:00 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
What remains stock? EVERYTHING on the '97 (at 76K miles) except the rear wheel bearings.
Now the '92? The following has been replaced: engine, trans, rear end.
VERY GOOD question, Ron!!!!!
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 01-21-2011, 09:56 PM
Invisible avatar
Angry Re: Who's driving with original parts?
So what about that highly modified race-tuned exhaust system?
G stock indeed!
Ron.
'01 Miata SE - 79K
Old 01-22-2011, 07:19 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Just the manual tranny and sterio and brake parts are not orginal.
Everting else i bye for this car comes from Subaru FUJI HEAVY INDUSTRIES LTD (made in japan) Cost litte more but i think my car is worth it.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 01-22-2011, 09:42 AM
newsvx's Avatar
G stock indeed!
Ron.
The exhaust system is ALL "back to stock" ..... now, the '92 is another question ......... - a special from Ole Tom ...
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
Old 03-03-2011, 01:18 PM
dromano's Avatar
dromano dromano is offline
My 92 has a 10/91 body plate. 122k miles, still have original tranny. Have replaced front CV axles, radiator, crank pulley & all valve cover/front engine oil gaskets/seals. Slotted cryovaced rotors up front. Front wipers have not worked since 2001.
Run synthetics in the tranny, engine & both diffs.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
