Old 08-22-2002, 06:13 PM
Re: bumps
Originally posted by amuse
I'll get the Oring replaced either way, but the it's actually the whole rear of the car physically bumping up and down as the wheels rotate that I'm experiencing, and yes it happens only when turning very tightly and moreso when tiurning Right versus turning left....
Thanks again for your input!
Would you have an estimate on how much replacing an Oring would typically cost?
Cheers,
Pete.
Well that sounds strange mate, try the fuse to see if it is the same feeling. Though from the right verses left thing I don't know. It could be a half shaft joint problem in the rear.
The O ring, about 1 hour labour plus 1lt oil plus $2 O ring.
Old 08-22-2002, 06:24 PM
Boone
Remember, there is a description of the O ring replacement in the how-to locker. It's easy to do yourself.
Old 08-22-2002, 07:11 PM
Ticallion
Angry
Easy to say "put the fuse in". The nut biter that did the engine shampoo ripped the sticker off, incredibly enough.
Which fuse is it?
Old 08-22-2002, 07:14 PM
amuse
Thanks Boone, but I'm pretty hesitant - never touched the inside of a car before...
Old 08-22-2002, 07:32 PM
immortal_suby's Avatar
Thread Killah
Here's the fusebox w/ the location circled
Locker Link
2015 BRZ Limited 6MT
Old 08-22-2002, 07:33 PM
Thread Killah
Inside - put the fuse in here
Locker Link
Old 08-22-2002, 07:38 PM
Boone
Which fuse is it?
In the driver's side underhood fuse box there are 2 fuse positions by themselves at the front by the edge of the fender. One is filled one is not. The empty one is the FWD spot. It probably has grease in it. Fill it with a 10 amp and confirm that the FWD is lit in the gauge cluster.
nice pics, immortal
Old 08-22-2002, 08:05 PM
Invisible avatar
Question
nice pics, immortal
Hey, Boone, "driver's side" is the "other side" on Oz cars.
Were the underhood (bonnet) goodies also reversed?
If not, the gentleman's gonna stick a fuse in the air filter.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 08-22-2002, 08:09 PM
Boone
Ron.
Ticallion is from Ontario, as I remember we drive on the same side. I have no idea about the Aussie fuse box but I'd imagine the position is the same. (pass side) Fuse function is different 'tho.
Old 08-22-2002, 09:16 PM
Invisible avatar
Talking
Nah - dem Canucks drive all over da road, eh? I thought the original question came from amuse, of outback country.
Ron.
'01 Miata SE - 79K
Old 08-22-2002, 09:36 PM
You reminded me of a sound clip I have...
(I can't test it so if it doesn't work I'll fix it later)
Old 08-22-2002, 10:26 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
That, my Canadian friend, is ABSOLUTELY hilarious.
Politically Incorrect, mind you, but nonetheless.
VK
