Old 02-28-2010, 10:02 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Check Engine Light "ON"
Ok - so now that I've had the car since 1998, I have my first "check engine" warning light come on while travelling to work.....
The car is NZ new (not JDM) - with 143,000kms.
So where can I find diagnostics information for OBD1 type car (built 12/94 - on drivers door side plate).
Trevor,
I know that you have a set of manuals for cars "down under" - just wondering if the "how to get into diagnostics mode" is different from USA (rest of world) as NZ/Aust had full time AWD & variable front/back drive splits etc.
thanks
Stephen
(1 OF 1)
Old 02-28-2010, 02:18 PM
dynomatt dynomatt is offline
Re: Check Engine Light "ON"
Hi Stephen,
I used the US spec procedure to get into my AU spec 95 without any issues.
As far as I know, it's exactly the same procedure.
M
Old 02-28-2010, 02:44 PM
SURTEESS's Avatar
Cool Re: Check Engine Light "ON"
Thanks for that - have a printout so will try tonight.
Old 02-28-2010, 04:03 PM
Kia ora Stephen,
Depends on year/model. Give me a call. Refer PM.
Regards, Trevor.
Old 02-28-2010, 09:26 PM
SURTEESS's Avatar
Trevor,
thanks for pointing me in the right direction "code 21" = ATF TEMPERATURE SENSOR.
Now the next question is how much should I pay for one ???
Does anyone know the p/n
Any help ....
Steve in NZ
Old 03-01-2010, 02:36 PM
Any reason why the differences are secret?
I'm confused...I used the advice on this forum and it worked for me.
Are you able to share this information as presumeably, for those of us with AU/NZ models, it's pretty critical information.
Old 03-01-2010, 03:02 PM
You have not missed out on anything.
The differences being referred to, involved year and model and applicable code read out system. It is now confirmed that Surtees car is as per 1992 Subaru Manuals.
Old 03-01-2010, 03:06 PM
The only difference would be 96 and up being OBDII systems in which case the kick panel diagnostic is not there
Correct me if I'm wrong, but I believe they put OBDII systems into all of the SVXi in 96 and 97 produced worldwide.
Old 03-01-2010, 04:24 PM
SURTEESS's Avatar
That is right - mine has the kick panel diagnostics available - hence found out that error code = 21.
So car is heading in for a full service this weekend - it has only done 8000km in 3 years!!
Old 03-01-2010, 06:14 PM
Nate, this is not totally correct. OBD 11 is a protocol put together primarily for the US market. Its claim to fame is that all readers [in theory] can read every manufacturers code. It was designed to stop manufacturers trying to hold all service work at the marque dealers, to the detriment of free trade and competition.
It's interesting if the Australia models use OBD 11. To the best of my knowledge UK cars of the post 96 variety use some European protocol, which is not the same as OBD 11
Old 03-01-2010, 08:21 PM
Alright, Joe. I was just pretty sure many manufacturers began changing all diagnostic systems to OBDII because it was "simplified" in the fact that you only needed one plug for all makes. I am fully aware that it was put into "law" by the US auto industy standards and wasn't required elsewhere but that most manufacturers began making all their cars with that system as it's easier to just simply use one system on all cars rather than different setups for different markets.
Sorry if that doesn't make sense. Thanks for clearing that up though, Joe Maybe we should have members in different markets check their 96+ production modeled SVX.
Old 03-03-2010, 01:25 AM
AUSVX AUSVX is offline
Registered Loser
Hey, I got them to change it for me when I had the gearbox rebuilt I think it was like $60.
I'm not 100% sure because I didn't fit it but can anyone confirm if you need to take the valve body off to fit it? Because that's where the real cost will be revealed.
