Old 02-19-2010, 07:00 PM
MY Owners ATTN please
I need a TCU for a VTD SVX w/ a front diff speed sensor... Do any of you guys that did the conversion have your old one left over?
Old 02-19-2010, 07:56 PM
dynomatt dynomatt is offline
Re: MY Owners ATTN please
Nothing from me sorry.
M
Old 02-19-2010, 07:59 PM
Don't have that one in Aust, it would have to come from a JDM front cut. There have been a few brought in.
NZ would be the best bet. Make sure that it matches the C solenoid that is in the rear end you are using.
Old 02-19-2010, 08:00 PM
It is the yellow wire normally closed sol... I was wondering if the AU model ever had the front sensor... thnx
Old 02-19-2010, 09:17 PM
Yellow is the N/O early model 92 to 94, so you should find that one easier. How big a hurry are you in?
Old 02-19-2010, 09:45 PM
Well, with any luck I will get the trans out this weekend and be able to drop it off this week at the rebuilder's...
Maybe a week or two later to get it back and reinstall it...
Not really a huge rush, I can convert the AWD later on, its not too bad to do. But if it is possible I would like to do it with the trans on a bench rather than in the car
Old 02-20-2010, 07:52 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I believe it's possible to install the JDM VTD software onto the USDM TCU hardware.
I've carefully compared the JDM and USDM circuit boards. The only hardware difference I can see is one extra small resistor on the USDM which I assume is to enable the atmospheric pressure signal - JDM doesn't need it but won't care if it has it. So I'm pretty sure the JDM software will run fine on it.
I'm building one for somebody at the moment and I'd be happy to do one for you too if you can't find a JDM TCU.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 02-20-2010, 09:54 AM
Harvey said he might have a bead on one... If he has any trouble with it I would be glad to go that route
Old 02-21-2010, 10:29 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: MY Owners ATTN please
Ask Peter for what you require - he has 3 JDM models stipped down to bare shells.
psw@maxnet.co.nz
here is a link to some of his stuff -
http://www.trademe.co.nz/Browse/Sear...ch_suggested=0
regards
Stephen in Auckland
