Re: 1992 LS-L parts car
I will find out today for you. I have t pull the drivers side out regardless to get to one of the tracks for another member
I checked those windows and they do have some light vertical scratches in them, presumably form dirt in the felt guide pads. sorry.
anyone else? |
Right side door sill. It covers the seam of the carpet along the passenger door.
I can PM you with an offer if you would like. Thank you very much
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
I have to see if it's still there. Will check tomorrow morning.
Made a master list, see first post.
Hi
I need the driver's side Sill Plate? If that is what you call it. It is the plastic piece under the door. It needs to be gray with all the tabs. If you have the metal clips and the white plastic pieces that go into the body that would also be great. Thanks, Paul.
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
Hi I'm looking for the interior rear view mirror and the drivers door window switch cluster. Can you help? Cheers
I have both of those, make me an offer for them, shipping will be about ~$8.
guys asking about the sill plates....i checked and both are damaged pretty bad. Cracked and/or missing mounts tabs on the bottom. Sorry.
How does the radiator look?
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Windshield and master window switch?
Thanks for checking.
#28
Not bad, held coolant without a problem. I can remove the fans and inspect better tomorrow for you.
#29
Both are available. Windshield is a blue tint variant(blue sunstrip) |
Thread Tools | |
Display Modes | Rate This Thread |
