Old 08-08-2002, 07:30 PM
Bill
New to the Network
Hi All.
This is my first post, just registered (came up as a "junior member? Since I've just turned 50 I'll take it as a compliment. Or did I hit the wrong key?)
For some strange reason I have this urge to be an SVX owner. I need your (unbiased?) help to register a sanity check!
I use a car for work and pleasure, covering 25k to 30k miles a year, but I'm looking to buy at around £9,000, if I can find one in the UK.
Is this the car for me? I'll also need to find a good garage because I don't have time for any d-i-y maintenance.
So, am I mad, or have I discovered one of the most unique cars on the road?
Old 08-08-2002, 07:51 PM
Re: New to the Network
Originally posted by Bill
Hi All.
Right on both counts
Come and join the rest of us nutters, Bill
Old 08-08-2002, 08:04 PM
Bill
Thanks Harvey,
Insomnia is also a prerequisite it seems?
..............."time for bed", said Zebedee
Old 08-08-2002, 08:37 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
A thousand welcomes, Bill. Yes, Harvey has it sussed -- We're mad, we have a unique auto (I have two -- do I have it bad, or what?) and we, ourselves are somewhat unique.
Welcome aboard!!
Randy Johnson
Mike Davis -- at Reading VI
Old 08-09-2002, 01:40 AM
TonyShaleUK
Free straight jacket with every car
Welcome to the madhouse!
I too do the sort of mileage that you talk about. Had my SVX 13 months and have covered 23k miles with no breakdowns. Mines a 92 model year. Thing you have to watch is the cost of servicing every 7.5k miles. I use a local franchise at £20 an hour, so normal service is under a £100. Main service from Subaru in the order of £450!
Terriffic fun car to travel distances (one of my offices is 100 miles each way, so frequently travelling for 1.5 hours plus). Great, relaxing car. Comfy too - find it as good seat-wise as my previous Volvo.
Go for it!!
Old 08-09-2002, 01:06 PM
Go, buy one
You know you want one.
Like Tony, I do 17K+ annually in mine. It is well built and reliable. Up to a point.
Seriously, though, I have had gearbox trouble, and also a growling rear bearing. But aside from that, it is faultless.
It's a really nice car to drive, good sound system, comfortable, and of course unique.
You could buy more sensible cars, but at this money, you could not buy better.
Old 08-12-2002, 05:30 PM
Bill
What do you suggest I look out for when buying a second hand car, apart from a full service history?
I'd heard the gearbox is a problem, but is this just on early models up to '93 or so? Will a car with a re-conditioned gearbox be a bonus, or a sign of more problems to come?
As for wheel bearings, is there any way to tell the noise from general tyre rumble (bearing in mind I haven't driven one before).
Any other pointers would be appreciated.
One last point for UK members. I'm looking for a UK car, not a Japanese "grey" import, because I've been told Subaru dealers wont touch an import. Any experience of this?
Old 08-12-2002, 06:23 PM
Bill,
You ask good, but big questions.
"What do you suggest I look out for when buying a second hand car, apart from a full service history?"
Normal rules apply. The less owners, the better. Buy from elderly gents who no longer can fold up gracefully enough to get into the driver's seat.
Avoid[like the plague] younger owners who will discover by trial & error if you treat it like an Impreza or a motorbike, it will end up worth much less than either.
"I'd heard the gearbox is a problem, but is this just on early models up to '93 or so? Will a car with a re-conditioned gearbox be a bonus, or a sign of more problems to come?"
The gearbox suffers from heat. Later models cope better, but after '95. A recon box will[normally] indicate an earlier car. The [defective] oil cooler is in the rad. Beware a recon early[pre-'95] car, if the transmission specialists did not know enough to fit an extra transmission cooler as part of the remedy. They may well be[probably are!] experts, but are not sufficiently well informed about this particular problem.
"As for wheel bearings, is there any way to tell the noise from general tyre rumble (bearing in mind I haven't driven one before).
Any other pointers would be appreciated."
Yes.
Normal tyre roar is constant. In pitch. You will hear it, even while cruising through 30 mph zones, and is noisier when you open a window.
Bearing noise is more of a low growl, that changes directly in proportion to road speed. If you need to be certain, have someone else drive the car, fold down the rear seats from the back seat, you will be able to tell which wheel it is by sticking your head in the boot.
"One last point for UK members. I'm looking for a UK car, not a Japanese "grey" import, because I've been told Subaru dealers wont touch an import. Any experience of this?"
Tony??
Phil??
Best of luck with your search.
[My advice, you find a good Japanese spec car, do not be biased, think of your pocket. Servicing will cost the same, nothing will be unobtainable.]
Old 08-13-2002, 12:52 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
I cannot add a lot to Joe's comments, except that UK spec cars are MUCH MUCH better
My car is a 93 (92 model) and runs perfectly in every way. I have driven many different motors and this is definitely my favourite.
Just make sure that you aren't buying a dog, as with most cars, mechanical abuse always shows.
Welcome on board.
Andy
Old 08-13-2002, 02:12 PM
TonyShaleUK
Grey import
You are right about gey imports - Subaru won't touch them. And unless you borrow someone's UK chassis number, they won't order parts either! Bell & Colvill will help if you give them a part number.
I use a local specialist to look after mine, altho' apart from changing the steering rack and pcv valve (couldn't be bothered for the latter!), this has only been normal servicing - but then it's much cheaper than Subaru!
Good luck
Old 08-13-2002, 04:34 PM
Same here, more so.
Subaru main dealers do not want to touch my car. Knowing how much they don't know, I don't want them near it either, so it's mutual.
I need something done, I go to a specialist. With a lot of parts, it is cheaper to order them from the States, pay the carriage and duty, than to buy from locals. I order the parts from svxparts.com. The website is good, if time-consuming, and you can get Subie part numbers from it. I have done this, gone to a main dealer, and said, get me filter ao639.....whatever, and they get it no questions asked. If their price is multiples of the US price, I ship from the States, and wait for delivery.
The world is too small a place now to let car dealers keep screwing us. I don't think there is a Halford's in Dublin, but I may be wrong. Anybody getting parts from Halfords or other chains, please post up the part numbers and prices, so all the members will benefit.
