Old 08-05-2002, 08:14 AM
LarryIII LarryIII is offline
Tire changing and other musings
Hello All,
Saturday morning, in front of my house, I switched the rear tires & rims between the burundy '97 LSi (SUBYDOO) and the pearl '92 LSL (SVXY). It was hotter than H*** and I must have lost 10 lbs in perspiration. I will explain my reasons for this. Coming back from Indiana, I noticed that the sound from the rear of the car was very very loud. I sounded similar to posted descriptions of the dreaded wheel bearing sound.
The '97 was shod with pretty new Dunlop Sport 5000 AS tires all around. I couldn't tell if the sound was the tires or bearings. The '92 had half worn Yoko AVS dBs on three of it's wheel and one half worn Toyo Proxes T1-S on the right front.
I theorized that if I switched the back tires on both cars I would find out if the '97 sound is tires or bearings. Please don't post about different size tires (front/rear) being no good for the drive train. This will be a short duration test and there is enough slop loose tolerances in the '92 drive train to permit this.
The following is a summary of what is now on each car:
97 Burgundy (Bordeaux Pearl)LSI:
front: 2 light colored rims with new Dunlop Sport 5000 tires
rear: 2 dark colored rims with half worn Yoko AVS dB tires
92 Pearl LSL:
Left Front: dark colored rim with a half worn Yoko AVS dB tire
R-Front: dark colored rim with a half worn Toyo Proxes T1-S tire.
Rear: 2 light colored rims with new Dunlop Sport 5000 tires
Results:
The results are inconclusive to me. When I drive the 92 Pearly it is almost the same sound, but it is not as loud as on the '97.
When I drove the 97, now the sound seems to be coming from the front where the Dunlop tires are located.
Conclusion:
I will have to extend the test and switch the front tires next weekend to confirm the sound on the 97 as either tire noise or bad bearings.
If it is bad rear bearings I will be very disappointed. The 97 only has 47.5 k miles on it. It is covered by warranty.
Larry III
PS: I guess "My favorite S-Turn" may have finally caught up with me.
PPS: I guess I learned how to underline text on this site.
Old 08-05-2002, 09:42 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
Do you happen to have 4 tires that are the same? I'd run 4 of the same tires on both vehicles and take it from there.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 08-05-2002, 09:52 AM
mattski mattski is offline
I rotated tires front to back this Saturday and ran into a different problem. I could not find the lug nut wrench. It was not in the spare tire recess and the owner's manual makes no mention of its location. Is there a special hiding spot or is it just missing?
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 08-05-2002, 09:53 AM
Invisible avatar
Wink
I'd bet on the bearing, Larry. As you may remember I had 4 half worn Dunlops on the car when I bought it. There was always a very low drone coming from ? The sound was like a snowtire. The sound never got any louder in 25K miles, so I assumed it was the Dunlops. I then got the AVS dbs. Same sound! I took the car to the dealer for all the pre-anniversary trip maintenance. Had the bearings checked. Yup - one rear was bad. Replaced - QUIET!
And yours is under warranty? Go for it.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Lowered SVX
hot sun + physical labor = no weekend fun.
i just have time for those kinds of things on the weekend.
"Too much fun to drive!"
Old 08-05-2002, 12:32 PM
Maria
oh no, Larry!! Aye Aye Aye!!!!
Larry, I hate to consider myself an unwilling expert in this ('92, 7+ bearings), but I guess I am. I don't know if anyone has asked you (forgive me if you have) if you can tell which side it is coming from? Switching tires in your next weekend road test would help there as well. Does the noise increase with speed?
Obviously, tire noise will as well, but this is a definite growl.
maria
Old 08-05-2002, 12:52 PM
Boone
which side?
Taking a ride with one or both sides of the rear seat down will tell you which side offends. (split seats in later years) If you hear both sides, it's the not a bearing. (or mebbe both )
Old 08-05-2002, 02:40 PM
wawazat??'s Avatar
Yeah, I'm still around
Hah, rotate tires!
I pulled the engine out of my pearlie in the heat. The car will be gone soon, but the scar from the stitches will remain to remind me of her.
Todd
Down to none
Old 08-05-2002, 05:45 PM
dromano's Avatar
dromano dromano is offline
lug wrench
The OEM lug wrench would be in the black vinyl
tool pouch. A rachet and socket work better & you need a torque wrench to tighten properly.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
