Old 07-11-2002, 04:55 PM
CHRISSVXUK
Question OIL SEALS and stuff!!!!!
Hello every one just a quick brain pick! after my brush with the oil leak from hell I was advised to try some forte oil seal fix whitch seams to of done most of the trick ! but soon it will be time to change the seals and the cam belt.can anyone advise?
I have also bought some after market front discs and went mad and had them crossed drilled , they look great lets see how they perform in a few hundred miles. the discs came in at about fifty pounds each.
faq..... oi mate what is it ????
Old 07-12-2002, 07:28 AM
Question
Not sure what you are asking. What do you need to know about the cambelt and the seals?
Old 07-13-2002, 03:49 AM
CHRISSVXUK
Sorry ! what I am trying to find out is about the oil seal change.
I am told that it is going to be a big job so i am trying to locate a garage that will do a good job and not charge too much over the odds for the job, and while that job is being done should i change the cam belt.
Old 07-13-2002, 04:32 AM
Yes
Cam belt should be changed at 60K miles intervals. If you are changing oil seals at the front of the engine, and the cam belt is even near the 60K figure since the last change, put a new belt on. It has to come off anyway for the seal replacement.
Not sure what seals gave you trouble on the day of the meet, but age would be against them anyhow on a '92 car. They perish and harden.
Interesting point I learned from Beav. If your crankcase is under higher than normal pressure, this causes seepage past the seals. There are two small inexpensive valves that control this, the PCV valve[Positive Crankcase Ventilation] and the EGR valve, for Exhaust Gas Recirculation. I have not done mine yet, and I have leaky seals. If your dipstick is popping up all the time, there is too much pressure in the crankcase.
Best of luck with it.
Do you want to buy a RHD workshop manual? They are about £90 to £100 from Australia, and could save you a lot of money.
