Old 11-20-2007, 07:37 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
rear main was a breeze. However, cam caps are being a PITA. Also, never heard back about the cam seals...are the cam pulley's keyed to help me maintain alignment when I put them back on? I'm assuming they are, but a definitive yes/no would be great.
How do i get the sprocket off the end of the crankshaft so I can do the front seal? Puller?
Old 11-20-2007, 07:46 PM
cams and crank are keyed so just pop em off. Like I said, screwdriver is quick and easy as long as you don't go gauging it in there. Punch throught the cam caps and pop them out. OR grab a pair of channel locks and grab the caps and twist and pull them out
Old 11-21-2007, 07:21 AM
wawazat??'s Avatar
Yeah, I'm still around
Quoted to show the level of finesse YT uses when working on internal combustion engines
"Pop 'em off" "Punch throught (sic) the cam caps" "graba pair of channel locks and twist them out" Frustrated much with the kiddies Thomas
Down to none
Old 11-21-2007, 01:01 PM
today was....ugh... frustrating. But yeah, just need to be mindful of what you are doing and it is easy to get this stuff done
Old 11-22-2007, 01:56 AM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
Originally Posted by immortal_suby View Post
This was my laundry list when I pulled mine
14075AA021 Gskt Intake Collector (2)$10.33 $7.87
16175AA091 Throttle Chamber Gas $6.90 $5.26
15010AA133 Oil Pump Ay $152.95 $116.55
13270AA031 Gskt Rocker Cover Rh $20.95 $15.96
13294AA020 Gskt Rocker Cover $7.95 $6.06
13294AA030 Gskt Rocker Cover $7.95 $6.06
13272AA031 Gskt Rocker Cover Lh $20.95 $15.96
13293AA011 Gskt Rocker Cover No $7.95 $6.06
13293AA020 Gskt Rocker Cover No $7.95 $6.06
13271AA051 Wash Rocker Cvr $2.95 $2.25 (20)
21200AA072 Thermostat $12.25 $9.33
21236AA010 Thermostat Gasket $3.33 $2.54
21111AA033 Water Pump $108.28 $82.51
21114AA051 Gasket Water Pump $2.55 $1.94
13028AA120 Timing Belt $99.95 $76.16
806786040 Oil Seal $11.37 $8.66 (rear main seal)
14038AA010 Gskt Exhaust Manifol 9.57 14.58 (2)
806733030 Oil Seal $7.17 $5.46 $5.46 (front crank seal)
62101PA081 Sleeve Lock Regulator $9.95 $7.58
11126AA000 crush washer oil pan $0.61
806732150 Oilseal-32x45x8 $6.11 $12.22
Impressive and rather complete.
The only thing I don't see is the oil cover separator and new bolts for that:
P/N's
11831AA210 (qty. 1)
800406140 (qty. 5)
800406150 (qty. 1)
'92 SVX LS-L
Project Car for Open Road Racing
Old 12-08-2007, 01:00 AM
SVX10's Avatar
soooooooooooooo....
I've got the cam adjuster tool to loosen my cam bolts with no luck. ugh.
Plus, I can't get the toothed sprocket off my crankshaft. I guess 15 years and 170k miles has them on there pretty tight. Any ideas other than get a longer wrench?
Old 12-08-2007, 09:03 PM
svxman07's Avatar
svxman07 svxman07 is offline
Send a message via AIM to svxman07
cam caps
i replaced cam seals and valve cover gaskets when i did the water pump and timing belt and i didnt think i needed to replace the cam caps and now the dang things r leaking, i highly recomend u place the cam caps while u r at it
Old 01-13-2008, 01:48 PM
SVX10's Avatar
Need help...again
Well, all the seals and everything are done, but now I can't get the freakin' engine to mate to the trans. Any tips?
I have the T/O bearing and release fork installed on the transmission side as suggested in the Impreza service manual. I have the clutch installed on the engine side, of course, and I used the input shaft of a junker transmission (same transmission, though) to align the clutch. I've been able to get nuts on the 2 bottom bellhousing bolts, and the starter bolt is started. Can't get the Upper Passenger Side bolt to engage. I'm hesitant about just cranking down on the 3 engaged bolts cuz they're getting a bit heavy to turn.
When we get everything "aligned" and wiggle it to get it to go on farther, the driver's side top isn't moving very easily despite the lower bolt being perfectly aligned and everything looking parallel. No issues with the pins or anything either.
So, let me know what I should do.
Thanks
Old 01-13-2008, 08:48 PM
well... Put the trans in gear.... Use the driveshaft to try and turn the rear output shaft. If it doesn't turn or is very hard to turn the clutch disk is aligned with the input shaft. If you aligned the clutch pre-install there shouldn't be an issue with using the bolts to pull it together. If it is hanging up on the alignment pins... Thats fine to suck it together with the bolts... If not, there is another issue here and you should prob back it out and take a closer look at what might be worng
Tomn
Old 01-14-2008, 07:10 AM
Is this the same engine going back on the same transmission? If not make sure you don't have the alignment dowels doubled up....
Old 01-24-2008, 11:26 PM
SVX10's Avatar
yea...just needed to be more aggressive with the bolts. Pulled on just fine She's on the ground and functional now. Haven't driven her yet, though. Maybe this weekend.
