Old 11-03-2007, 10:50 PM
Removing Pistons
Has anyone had success with commercially available piston pin removers and piston circlip pliers? Due to their high cost, I am trying to avoid buying the specialty tools from subaru. Thanks, chris
Old 11-04-2007, 04:00 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Cut the handles off of a regular pair of long nose pliers and weld straight rods on.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-04-2007, 04:56 PM
Bill, if i do that will that suffice for both removal and installation of the circlips AND piston pins?
Old 11-04-2007, 05:25 PM
Would this work? http://www.sjdiscounttools.com/mtn1460.html
Old 11-06-2007, 09:49 AM
bump, anyone? Just want to make sure that these will work before i get them... thanks, chris
Old 11-06-2007, 02:57 PM
SVXRide's Avatar
Clips, yes. You'll need to fabricate a rod to gently press into the pin to remove them. LAN had a post where he discussed the one he machined up. You might also PM TOMSSVX to see what he's using to remove the pins.
-Bill
