Old 10-28-2007, 02:43 PM
Wikedjuggalo's Avatar
Rebuilding
How do I fix this :(
O.k it started with just the top of the driver side door being alittle loose. then it all 3 of what ever is holding it in broke, it is not hanging off but worries me because it is very loose, Anyone ever encountered this before? Because I wanna fix this, it is bothering me.
Old 10-28-2007, 02:51 PM
jeffast jeffast is offline
I kill more trannies then god
kinda looks like you might be able to glue it, if not, time for a new door panel
1991 xt6 eg33?
1993 gc track car
Old 10-28-2007, 03:47 PM
Take the door panel completely off and look to see if anything is (was) fastening behind it.
That's looking pretty rough. I have never heard of anyone disassembling the door panel. Glue might just be the answer.
Old 10-28-2007, 06:04 PM
SubaSteevo's Avatar
No longer blue member
It's been a while since I've had my door panels off, but I believe that part is held on by little plastic rivets. You should be able to replace them with some small screws without it being noticeable.
-Steve
01' MSM Lexus IS300
Old 10-28-2007, 06:41 PM
svxual's Avatar
svxual svxual is offline
yep i couldnt get that woodgrain panel off the door so broke the original clips altogether then pop-riveted it back on,, the back is just hard cardboard so i used some made up washers to hold the rivets properly from the back ... was quick and easy prob 10mins start to finish ( wanted the panel off to paint the woodgrain which is now black) and looks great im planning doing it to all my woodgrain as its very faded and looks tacky .. iv tried getting those dash kit cover things but have had no luck sourcing for a right hand drive ... yes iv tried smallcar..... they said no
Old 10-28-2007, 07:12 PM
Rebuilding
Is it difficult to remove the door panel?
On a different note, where does the hose, from what looks like a fuel something, (The black cylinder beside the ABS ) go ? it seems weird it is just sitting there. Looks like it is suppose to be plugged in somewhere. Its coming from the bottom on the Cylinder.
Old 10-28-2007, 07:32 PM
SubaSteevo's Avatar
To remove the door panel there are 2 visible screws near the hinge, 1 under the plastic cover near the handle, and 3 under the felt in the cubby slot. Then it just pops off.
The canister thing is a charcoal canister to reduce emissions. There should be an elbow shaped piece which attaches it to fender well.
-Steve
01' MSM Lexus IS300
Old 10-28-2007, 07:34 PM
Rebuilding
Thanks you for the quick reply, I have no school tomorrow but work so I should be able to get this problem fixed thanks to this networks help.
Old 10-28-2007, 07:36 PM
svxual's Avatar
nope pretty easy just undo the few screws and gently pull it out i used big flat head screwdriver so as not to break the plastic bung things that hold the panel on!! once you have it released from the door itself reach ur hand in behind and unplug your window control etc then its free to do with what you want... hint!! nows the time to replace those front speakers while the panel is off!! i did but thats another story i did what we in new zealand call a bit of ( a maori job) lol but damn my door looks good and my sounds sound good
