Old 10-25-2007, 03:04 PM
Hop Hop is offline
Classic SVX
Waterfall adjustment
Somebody bumped my waterfall. It doesn't budge and I'm afraid of breaking it. Are there any adjustments that I might not know of?
Old 10-25-2007, 03:23 PM
nextse7en's Avatar
Graphic Artist
It doesn't adjust, it looks like a tab may have broken off at the bottom.
The easiest way to remove it it to pull the top forward to you, one side at a time, and insert a screwdriver into those holes at the top and gently press the tabs in on each side, once you loosen the top, just roll it toward you.
You'll be able to put it back in the right way once you see how its attached, its pretty simple.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 10-25-2007, 07:21 PM
Hop Hop is offline
Classic SVX
Hi Patrick,
I was able to put a pair of needle nose pliers into the slots in the top to close the clips. The waterfall should have rolled right out. It's wedged in there. I put a crowbar on top and pushed until i heard the plastic crackling. The thing wouldn't budge. Perhaps when I take the lights out when the new ones arrive it'll be easier.
