symptoms of bad cps??
can someone tell me the symptoms of a bad camshaft position sensor?? thanks
Wouldn't there be a Check Engine light popping on? And also the code for it would appear ?
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Poor starting no matter what the temperature of the car is usually the case of a broken/failing sensor.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
the car won't start...
I seem to remember that Dan had a problem with his that YT diagnosed and fixed.... -Bill
well what controls the ignition, cuzz im having excessive back firing when it has hesitation, no CEL, and no power light is on, im unable to check what the cell meens because when i went to go put one of the two blue wires into the black connecter, the top left 2nd pin wasnt there..... and i did have a CEL for a misfire in cylinder 2, swapped it with cyl. 1 and ran good like it was running with 6 cyl., and no CEL, but still getting a bad hesitation...
What year is your car?
ODB II systems that can indicate which cylinder is mis-firing can't be self read with the blue wires, you need a code reader ODB I systems, can be self read with the blue wires, but won't indicate a specific cylinder misfire.
i have a 96
