Ok, so I finally replaced the Coolant temperature sensor.... $25 at autozone. But... well... I dont know, I mean, I gotta say it deffinetly feels WAY better... but the problem is still there. Lets say the problem went from a 100% to a 70% or 65%
Its not running as rough as it was, but still from lets say 0% to 50% of the gas pedal it still misfires or something.... but deffinelty not as bad as before. So the problem just got smaller, wich is fine.... but Im very frustrated.... Any more ideas???? PLEASE HEEELLPPP!!!!!! |
hmm did you check the coolant temperature plug/harness for corrotion?
Yup, it was fine, i sprayed it with WD40 and cleaned it. Its deffinetly working because the car feels a lot better than before... What could be next?? Spark Plugs?? Sensors?? BBUUAAAAA |
.............. so............. nobody??
Will it trow a code even if the check engine light is not lit??? Also... I saw this throttle body coolant bypass thing... what is it for?? Makes the car run any better?? Wont affect on cold weather?? |
Keep looking for vac. hoses. When the engine is cold, it likes more air as it is programmed richer, but when it warms up then it will be too lean and not so happy.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
Did you check out your O2 sensors? One of mine was FUBARED and cause mine to run weird, just at higher rpms/speed. It could have something to do with it.
bLAh
Well, this morning was pretty cold and still misfired like crazy.... when usually it worked fine while cold.... Quote:
I want to take the car to the grand canyon in 2 weeks.... so I have to fix this as soon as possible.... |
Make sure the wiring is right too, because mine was hot wired into the harness and didn't have the plug used for SVXs.
bLAh
Well, I know nobody has touched it in a year, and the car was working fine and it suddenly started running rough.. But I'll check it out for shure Thanx
My car started running rough like similar to your a while back after a particularly cold day. Took it to the shop, they ended up changing out two injectors and two coils and it started running fine. I think they were just changing stuff out, until they finally hit the right one.
So try doing this, start the car and while it is running rough .. - disconnect one of the injectors, if the car runs worse, you know it was working properly, reconnect it and move to the next one. - The one that when disconnected does not make any difference in the way the engine runs is the culprit ie: could be the plug or the coil or the injector for that cylinder. Good luck. |
What about when it's just sitting there? While it's parked if you rev it up, does it run rough, or is it just when it's under a load?
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
Funny thing... i just noticed today it ran fine all the way from work to home.... it makes me feel it could be a dirty connector or a false on a cable or something..... |
#28
Ok. Lets break this down
First if you have a misfire, Its not a coolent temp sensor. It means you are not getting spark somewhere. Also I just had to replace the Mass Air Metor on mine. It was kinda the same symptoms. And my CEL wasn't always on for that one. So if its not that, I bet you have one or more coils bad. Happened on my Mustang a few times. If you give the car anything over half throttle you are forcing air (MAF) and energy and the symptoms seem to go away. You can always diagnose something like this while under a lowend load. Your ECU is fine. It seems on this board that people think way too deep on things. Take it for face value at first. Do you clean your engine and spray water on it? That KILLS coils/plug boots. Water gets down inside the hole. It takes some time forthis problem to show its ugly face sometimes.
92 Lsi Pearly White. All stock. . .and that's fine by me. 2000 Mustang GT NOT stock 450 rwhp |
#29
92 Lsi Pearly White. All stock. . .and that's fine by me. 2000 Mustang GT NOT stock 450 rwhp Last edited by Back IN Black; 11-07-2007 at 08:08 AM. Reason: spell |
#30
I really apreciate everybody's help I couldt go trough all of this by myself. I'll keep you updated. |
