Old 07-12-2007, 06:31 AM
ebaybrad ebaybrad is offline
binding problem - i know i know....
This has been done many times. I read through all the prev threads with conflicting info.
I get a groan when turning heavy at low speeds and while parking. at near full lock it binds alot. I put the fwd fuse in and it is like a different car! No binding or groaning? Is it dangerous to drive in fwd>? I would think that the gas mileage would be better and i like the pulling feel? I could put the fuse back in in the bad weather....
Anyway, i would like to fix the source of the bind problem if someone with better reading comprehension skills could chime in..
thanks
"Never ask a barber if you need a haircut" - Warren Buffett
2006 Merc R350 (wife's car)
2003 M3 SMG coupe (for now)
1996 SVX LSI 28k
2004 Burberry Jaguar electric car (daughter's car)
coming soon... 2006 Noble m400
Old 07-12-2007, 08:17 AM
Mr. Pockets's Avatar
Moderator
First of all, please post in the appropriate forum in the future. I have moved this thread to tech q&a for you. Please don't make me do it again; it makes me grumpy.
Using the FWD fuse will not, as I understand it, harm your car. All you're doing is preventing the transfer clutch from being used at all. Effectively, your car is now FWD. Go figure.
Please try to avoid spinning the front wheels while you are using the FWD fuse.
The binding is likely caused by a bad transfer clutch solenoid. The part isn't terribly expensive, but the labor can be. You might as well replace the transfer clutch while you're at it.
I have no idea whether your gas mileage will improve, but if you're getting a kick out of the 'pulling feel,' I highly doubt you're about to see significant gains.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-12-2007, 09:57 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I have this issue, but mine is not in hte mechanics, but likely in the wiring between the TCU and solenoid c. I would go to solenoid c with a volt meter and test the voltage going to it. When FWD is engaged it should be betweene 8-14volts, applying voltage to the solenoid keeping it in fwd mode. When slipping is detected, the voltage drops to between 0-0.5v and it opens allowing 4wd to engage.
Without the FWD fuse in, test the voltage. If your getting current, then the solenoid may be bad.
Go here:
http://www.subaru-svx.net/photos/fil...ye95/12431.PDF
Page 18 should start giving you ideas on how to diagnose the problem.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 07-12-2007, 11:19 AM
cdvs cdvs is offline
If putting the FWD fuse in stops the binding and gives you the FWD light, then solenoid C (transfer clutch) is working. However, it may not be working properly. In normal mode, it should be allowing partial transfer to the rear wheels, which will allow the transfer clutch to slip when needed, and only full transfer when the front wheels slip. I suspect you should be prepared to replace the transfer clutches as well as the solenoid and valve body.
Good luck!
Charl
Old 07-13-2007, 06:12 AM
dcarrb dcarrb is offline
You won't get better gas mileage. The engine's turning the same driveline and lugging the same weight, no matter which wheels are moving the car.
I know there must be a thousand threads on this topic, and I don't want to muddy the waters (as all I know about this matter is what I've gleaned from here), but I thought the opposite to be true; that having the fuse cure a binding condition suggests the solenoid is shot.
dcb
Old 07-13-2007, 06:20 AM
dcb
Soleniod C disengages the transfer clutch. The FWD fuse engages soleniod C. Failure mode is full transfer.
Old 07-13-2007, 08:56 AM
i gotta tell ya that I like the way the car feels in FWD mode. It feels faster, lighter, and smoother. I think that I might leave it this way unless the weather is bad or in the winter. I am going to fix the transfer clutch etc...
I still am conflicted in the information about the solenoid c as I read completely opposite answers to the same question...
thank for the help though to all..
1996 SVX LSI 28k
Old 07-13-2007, 09:04 AM
Could be you prefer FWD simply because you've never driven one with properly-functioning all-wheel drive. If the AWD binds-up badly in turns, of course it's going to feel better in FWD.
Note that my input on solenoid C wasn't an answer, it was an expression of confusion.
dcb
Old 07-21-2007, 02:42 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
I have had binding for a long time now. I remember reading that if the binding stops when you insert the fwd fuse, then you have a bad sol C. I replaced Sol C and the binding is still there. What could the problem be? transfer clutches??
Ive been driving with the fwd fuse in for almost a year now because the binding has gotten so bad. Also, sometimes while driving, the fwd light will turn off and the car will go into awd. If i turn off the key and restart the engine while driving, the fwd will usually come back. This gets very annoying though. Ideas?
Im thinking of just replacing the whole transmission.
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 07-21-2007, 07:50 PM
JaySVX's Avatar
Check to make sure your getting good voltage between the tcu and the sol c. My entire tranny was replaced, and it still binds. The tcu was replaced and it still binds. That leaves one possible solution as far as i can tell, and that's the wiring between the tranny and hte tcu. I haven't had 5spare minutes to jumper around it to see if it works, but hopefully i will this upcoming week.
On a second note, my problem is "intermittent", sometimes i would, sometimes it wouldn't. When i would go to start and couldn't get it to engage normal operation, turning it off and restarting it, and repeat the process for up to 30min, i'd normally give up and put in the fwd fuse and drive it to where i needed to go. I didn't like doing that though. Well, i've learned my lesson. Something burned. FWD fuse does not operate as it should anymore. FWD will light up on my dash when i'm in fwd mode, but even with the fwd fuse in, it's not always, only sometimes. I start my car, and if fwd doesn't light up, i have to shut down and try again. With the fuse in i'm not getting fwd function, only the fwd light in the event that it's not binding.
In short, inserting the fwd fuse if you have binding issues is not a good long term fix. I was using it only when i couldn't get fwd to engage, and boom, it no longer functions for me.
Old 07-21-2007, 09:52 PM
Merz's Avatar
Keep me updated if you figure out whats wrong. Seems like we have similar problems. Sometimes my binding is worse than other times, and sometimes the fwd works, sometimes it doesnt. I replaced sol c and it didnt help. Id hate to end up replacing the transmission and have the binding still be there. Im not very familiar with the wiring of the car. I know where the tcu is but not which wires go to the sol c, or what the voltage is supposed to be. I'll search the network later for a wiring diagram. thanks for the help. good luck.
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 07-22-2007, 04:11 AM
SOLENOID "C".
A pulse width modulated solenoid valve, this device is arranged to adjust control pressure to the centre differential, or alternatively clutch actuating mechanism. According to model. Solenoid “C” operates along the same lines as solenoid A and cycles continuously. However the duty is in no way as arduous as that involving constant control of line pressure and no parallel secondary circuit is incorporated. Transmissions equipped with a centre clutch, incorporate a normally closed solenoid, whereas those with a centre differential, a normally open.
Old 10-17-2007, 11:41 AM
Wocketman Wocketman is offline
AWD binding....
I know this is an older thread, but I'm digging to find a solution to my own AWD binding issue. As with some of the other posters, I find that putting in the FWD fuse usually does NOT disengage the AWD...only sometimes when I'm lucky...:-(
I did a voltage test on the hot side of the FWD fuse plug-in...and only got about 6V. I would imagine that it should be 12v?? Do I have a problem in whatever provides current to that fuse, or is it supposed to be only 6V?
Any help appreciated. My AWD binding is getting worse, and I want to go FWD as often as possible to avoid wearing things out while I save up up $ for a real fix...
Bruce
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 10-17-2007, 11:48 AM
redlightningsvx's Avatar
Collision Refinishing Tech
check wheel bearings
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-17-2007, 12:05 PM
AWD binding...
Huh? I don't hear any wheel bearing noise...just clunks front or rear when turning backing up, or when going fwd in tight turns. All SEEMS ok when going straight....could wheel bearings still be an issue?
Bruce Schwab
www.bruceschwab.com
