Old 05-12-2007, 07:52 AM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Originally Posted by TomsSVX
Dan... Tom was saying the same thing today but I was determined to believe that if the ignition switch was the culprit, the indicator lights would at least flash. Did ur dash light flicker when it randomly missed?? I will see what I can do about picking up another switch (not the keyed part but the electrical portion. We can give that a go. My money is on that since those plugs are brand new and they weren't mishandled
I didn't see the dash light flicker, but it's possible it did so briefly I missed it.
Used to have: 1994 Pearlie, 40,945 miles, PWR Radiator, Motorsports Aluminum Crank Pulley, Raceconcepts Stainless Brake Lines, Axxis Ceramic Brake Pads, ATE Super Blue Racing Brake Fluid, Dimpled/Slotted Rotors, BBS STi 17 Silver Wheels, Toyo Proxe4 225/45/17 tires, New Dekka Battery, Unauthordox Racing Oil Cap -- adds 3.14 hp, OEM Coin Holder FFTDS aka Force Field Theft Deterent System. Magnetic oil drain plug, Purolator larger oil filter. Now she's in good caring hands at Earls place.
Old 05-12-2007, 08:28 AM
Originally Posted by AJ4U2
Had the same problem for about 2 months nobody could find the problem..I change the ignition switch and problem is gone.
Dan, I was trying to ask him^ if his lights flickered.
Trevor... this is a very troublesome problem. I need to look at the wiring for the ignition switch but i am not sure I whic wires I would need to bridge... Just seems a little too off the wall for the ignition to drop its current randomly and only at speed
Old 05-12-2007, 09:09 AM
ShiuludeSVX's Avatar
Originally Posted by Trevor
Sorry but this does not apply, as the SVX has coils on the plugs. As I pointed out the wires do not carry a high tension voltage.
Thanks. There I go, jumping for answers again.
Hope it gets figured out.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 05-12-2007, 09:19 AM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
It only does it above 55MPH below it was ok, I change the switch and all was ok from then on...don't know what happen to the switch but it cured it..
One of those weird problems i guess..
Old 05-12-2007, 05:58 PM
Not a worry. My intent was simply to prevent possible confusion and most certainly not to take you to task.
Your reply well and truly indicates your integrity, honesty and attitude, as I hope many have noticed.
Old 05-12-2007, 07:12 PM
Tom,
Yes off the wall for sure, but elctrickery is like that.
My intent was to save you some frustration, if you decided to proceed down this path. The problem could exist even, though the lights do not flicker, given the possible time delay.
In the event that you wish to proceed, you could hot wire from battery positive to of fuse No. 18, so as to provide a parallel direct feed to the ignition switched circuitry. In the circumstances, you will have to leave a link in place during test runs over a period.
I suggest that you make up a lead fitted with a clip which can be attached/detached from the battery and incorporating a 10 -15 amp in line fuse, then insert some strands with fuse 18. Make certain the circuit is complete with the ignition switch off, and you will be in business.
Be assured that this will be much simpler than messing about with the ignition switch and associated wiring.
Old 05-12-2007, 09:23 PM
If I can find a good ignition switch I will pick one up. If not, I will go ahead and try to hotwire the ignition as you have stated... I just cannot figure why it would only do it at speed... I guess it could be the resonance of vibrations that causes a short but thats a stretch... Just doesn't make logical sense even if it physically fixes the problem
tom
Old 05-12-2007, 09:46 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
What type of air filter does the car have? (Yes, this is relevant)
Swap out the MAF just for a moment with another SVX then drive and see if the problem goes away. Would love to hear the results.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 05-12-2007, 09:47 PM
DanSVX94's Avatar
Ren-Ma Osu
I called Subaruparts.com. I can buy a new ignition switch for about $38.00 plus shipping -- part# 83131PA00
The person I spoke to named George also suggested:
check wiring to injector, all connections to ignition, all connections to injectors, all relay connections, check all grounds, control unit connection -- he said that because the car wasn't driven a lot it could be a corrosion problem.
The car has an OEM Subaru air filter -- new in January 07 -- bought as part of the tune up kit from Subaruparts.
Old 05-12-2007, 09:57 PM
George has certainly covered his tracks. How could he be wrong.
Bridging the ignition will get number one suspect out of the way. Don't be tempted to grope about. Science is your friend.
Old 05-12-2007, 10:03 PM
Dan... I checked all those connections for visual fault the other day... I took a lot of time under that hood just waiting for something to be out of place... Chris, I have dealt with this issue before and a MAF does not fix it... I cleaned his with MAF cleaner to no difference
Old 05-12-2007, 10:20 PM
UPnorth362's Avatar
UPnorth362 UPnorth362 is offline
Send a message via Yahoo to UPnorth362
I haven't checked to see if you posted or not. But have you checked to see if you have a leaky injector or injectors. The injectors have O rings in side the actual injector. If you use a lot of fuel cleaner, gas with alcohol, or a high water concentration in the gas, it can make the O ring crack 0and the injector will not be accurate. You could notice this at low rpm, high load when the cylinders don't burn as efficient.
You would probably need to replace the whole injector, or send it to be flo tested. You could also have bad O rings the seal the injector in the rail.
Just a thought
IT'S 5:00 SOMEWHERE!!!
92 Liquid Silver SVX LS-L
Old 05-14-2007, 09:19 AM
AJ4U2's Avatar
Has anyone figure this out yet... Just curious
Old 05-15-2007, 02:11 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
And no codes from the SVX?
Have you to tried taking it to get the fuel injectors professional cleaned? Maybe one is bad?? Just a guess...
Marisa
Old 05-15-2007, 07:10 AM
DanSVX94's Avatar
Ren-Ma Osu
I ordered a switch assembly ($38) from subaruparts.com. I should have it by Monday and we'll see if that helps.
