Old 05-02-2007, 11:07 AM
A new twist on the Manual Swap....
I wanted to try something a little...different...so I made it a 5-speed REAR wheel drive car....with the stock 3.54 LSD rear diff....
SO it keeps the better highway RPMs and is a manual tranny.
I've updated to WRX motor mounts while I was in there, and an Excedy CLutch & PP.
So what do you think...?
I haven't decided if I want to keep it like this, or go back to AWD on it...
(Rear Wheel Burnouts are cool..... ...and I grew up driving Firebirds, which is sort of what it drives like now)
Give me your thoughts...
I've gotten some thoughts from the crew over at XT6.net, but figured this is where I'd get the most response....since it is in a SVX after all
Old 05-02-2007, 11:14 AM
DO IT!
If you go full bore at this, could you remove all of the front wheel drive parts? Axles obviously, but could you also remove the front diff and anything else in the trans that's not needed? A 5MT is already a weight savings over the 4EAT, removing some parts would be even better, plus help the weight distribution.
Old 05-02-2007, 11:17 AM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
You need to post video!!!!
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 05-02-2007, 11:25 AM
I've already done it...no front axles, just stubs in the spindles to hold the bearings together....
Old 05-02-2007, 11:26 AM
Maybe if I put on an old set of tires, so I don't trash my new ones....
Old 05-02-2007, 11:51 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Awesome, i was thinking about something like that, but i have a hundred things to try before. Just a rwd tranny strait back to the rear right?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-02-2007, 12:31 PM
Pretty much, with a locked center diff...
Old 05-02-2007, 12:33 PM
JaySVX's Avatar
Very nice, i had actually toyed iwth the idea, but was far from putting it into production. Could you use a different center clutch that was designed for a rwd car? I guess that would be hard to find since all the subaru's are awd that we get parts from, but perhaps...
Old 05-02-2007, 12:43 PM
No newer gen Subaru was ever offered with Rear Wheel Drive....some were Front Wheel Drive though....but what fun is that
I just wanted to see what it'd be like
I haven't driven it in the rain yet
Old 05-02-2007, 12:49 PM
a 6mt is the best of both worlds so I really don' thave much a desire to convert. Its rwd for the most part.... but when u need it, its still AWD
Old 05-02-2007, 12:55 PM
The 6mt is great and all.....but I did my whole swap for less than half the cost of a 6 speed....
I work on a shoestring budget.....
Old 05-02-2007, 01:03 PM
yeah I know the feeling... You used the 3.9 turbo leg tranny right?? My only concern is running 100% power not only through the driveshaft but also the rear and axles...Good luck I am sure its a blast to whip around
Old 05-02-2007, 01:10 PM
JaySVX's Avatar
It's cool and all, i wouldn't do it for functionality though. I'd do it so i could say "hey like my rwd svx?"
Old 05-02-2007, 03:07 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Sounds like a blast. Bring it to Reading next year and do burnouts.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 05-02-2007, 03:47 PM
Home thoughts from abroad...
That sure is different Huck. Trust you!! You're a Daddy again. The father of the RWD SVX.
I think you should keep it for a number of reasons. Being unique is one, but it is also only the start.
If you decide to go forced induction, then you should end up with a very quick quarter mile car.
Without going totally "funny car" on it, I think the style of the SVX would lend itself to some sensitive modification at the back.
With all the horsepower now going through the rears, you should now be able to "grow" the rear wheels and give yourself more contact area for traction. Because you are not AWD any more, you could even consider having the rear a taller rolling radius, which also would help your highway RPMs.
[I would also consider a stronger and stiffer rear diff to keep the power down without breaking stuff.]
As you would be going wider with the wheels, this would mean a good excuse to grow the rear wheel-arch bulge. Not to make it an in-yer-face racer or ricer or drift style, just a bigger bulged version of the OEM wing [you guys call them fenders, sorry, forgot].
Oh how beautiful that would look on the road.
I know you work on a budget Huck, but I hope you do it.
